Results 1 to 5 of 5
Thread: Sound Blaster Audigy ZX2 Platinum
    Jul 2009
    B.C., Canada
    What do you guys think of this sound card for a carPC? It's old, I think I bought it in 2004 but it was top of the line (for Creative anyways) at the time and it's just sitting in my unused computer in the basement.
    Here are the only specs I could still find
    Jul 2009
    B.C., Canada
    No one's used this?
    Nevermind it's a ZS2, not ZX2 and that brought up a bunch of results from the search.
    May 2005
    Stockholm
    If you don't have very very high demands on the sound your soundblaster Audigy 2 ZS will be more than okey.
    If you compare the Audigy 2 ZS with home amplifier Pioneers old AX10i had similair singal noise values. This can give you a hint it will probably be okey for you in a carPC setup.
    You can read more about soundcards in the caraudio section in the forum.
    Soundblaster Audigy and Audigy 2 cards usually can use the KX drivers. There is some cards that are not compatible with them but I think your can use them.
    I can recomend you to use this drivers instead of Soundblasters own. Search for KX driver in the forum and you will find all information you need.
    Good luck
    Oct 2006
    creative is known to have buggy hibernate/resume issues.
    look it up first before deciding.
    Jul 2009
    B.C., Canada
    I do have "very very high demands" as far as audio goes and I will for sure upgrade the sound card. Right now I'm paying off student loans as I build this so as long as the Audigy 2 ZS sounds "good" I'll use it for now since it's just sitting in an unused desktop at the moment.
    I've read about the hibernate issues and not that worried about it for now. It's work around-able.
  1. Sound Blaster Audigy SE
    By BLAXKINNED in forum Car Audio
    Last Post: 11-19-2008, 04:21 PM
  2. Creative Sound Blaster X-Fi Xmod USB
    By crispyrabbi in forum Car Audio
    Last Post: 06-11-2008, 05:24 AM
  3. disatisfied with Audigy 2 NX sound
    By chut in forum Car Audio
    Last Post: 04-13-2006, 04:30 PM
  4. Sound Blaster Live 24-bit 7.1 Audigy Sound Card
    By djXternal in forum General Hardware Discussion
    Last Post: 04-25-2005, 04:49 PM
  5. Replies: 0
    Last Post: 08-28-2004, 04:14 PM
