But then it would send voice to the coils in the sub, correct? I just want any sound, I want the LFE specifically, will this work?
Easy solution: If you're already amping your front speakers, use another RCA from it's pass-through to your sub amp.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
I currently have my PC going through my head unit but my plans are to remove the head unit eventually. I am interested to see how you get this working. Though I am using only on AMP as opposed to two separate.
"Live Free!!!...It's all about Open Source"
Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
Old Proj II
Old Proj I
YouTube:Project Videos
Homepage: HexxWorld.net
Twitter:http://twitter.com/hexxamillion
From what I read the D945GCLF only supports 4 channels...
"Desktop Board D945GCLF has a 4-channel (two independent 2-channel audio streams)" It says nothing about a 5th (4.1), 6th (5.0), or 7th channel
Thats why im getting the D945GCLF2 Which supports 5.1 audio
1998 Toyota Camry LE
DWW-750FM
RR 11/2/2006,
IG3,
DELL Inspiron 4000
Carnetix p1900
or save some money and get a $10-$50 external subwoofer crossover... like this:
http://www.sonicelectronix.com/item_...amid+CR66.html
I'll be damned, you're right. Here's what the manual says for the D945GCLF Audio:
Although further down in the document you get this:Audio • RealTek* ALC662 audio codec
• Support for Intel® High Definition Audio
• Support for 4-channel audio (two independent 2-channel audio streams)
What else would the microphone input be retasked to? For anyone interested, here's the manual for this board: http://www.intel.com/support/motherb.../CS-029157.htm• Back panel audio connectors that are configurable through the audio device
drivers:
― Line in/retasking jack
― Line out/retasking jack
― Mic in/retasking jack
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
So I tried this tonight and it worked perfect, thanks! I thought I'd get a bunch of voice sounds coming through to the subwoofer but I just set the passthrough on the other amplifier to LF (low frequency) and it pounds. It's probably even louder than it was before with running it from the motherboard. Sounds great.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
