Results 1 to 10 of 17
Thread: How do I get subwoofer working on D945GCLF motherboard?
    May 2006
    Calgary, Alberta
    I got the Intel D945GCLF and cannot figure out how to flip the microphone in port on the board to be a LFE (subwoofer) out port like I did with my old M10000. Has anyone done this? I installed every updated driver, all the audio drivers and I have 4 channel sound right now. I just cannot get 4.1 sound going.....I'll even settle for 2.1, I just want the subwoofer. Anyone know how to get this board to flip the microphone port to LFE?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jan 2008
    i don't know for the board(i have that board, but use a sound card), but another option would be to use a subwoofer crossover(about $15-$50) off the stereo channels to get the sub output.
    Variable Bitrate Deric's Avatar
    Sep 2006
    To get the sub/center to work on the intel you have to have all three ports used in the back. Unlike my desktop board the intel would not let me select which one was which. So I just used two ports to be the front and rear for my 4 channel amp and the last to be the sub channel on my factory amps. I have to use a front panel connection for the line in/mic
    Good luck
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Deric View Post
    I have this done. 2 of them go into the speaker amplifier and the bottom one goes into the subwoofer amplifier. No sound from the subwoofer.
    Huh? So there's no option to select which port is subwoofer out? I thought that's how they all are, only the microphone input can be switched to LFE.
    I tried that, no sound from the subwoofer and the Intel sound test in the application installed with the driver only test the 4 speakers, there's no subwoofer in the test.
    Good luck
    For the subwoofer or you actually use a microphone?
    Sorry, I still don't get what you're saying here, I tried using all the ports but that microphone input on the back just will not produce any output no matte what I do. Can you clarify?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    This is taken from the manual:
    Onboard Audio Subsystem
    Desktop Board D945GCLF has a 4-channel (two independent 2-channel audio streams)
    onboard audio subsystem that includes a Realtek ALC662 audio codec.
    The audio subsystem features:
    • Intel High Definition Audio interface
    • Advanced jack sense, for the back panel connectors, that enables the audio codec
    to recognize the device that is connected to an audio port and retask the connector
    via the audio driver.
    • S/N (signal-to-noise) ratio: 95 dB
    • Microphone input supporting:
    ― Stereo microphone
    ― Microphone boost
    The subsystem includes the following headers and connectors:
    • Front panel audio header, including functionality for:
    ― Line out
    ― Microphone in
    • Back panel audio connectors that are configurable through the audio device
    drivers:
    ― Line in/retasking jack
    ― Line out/retasking jack
    ― Mic in/retasking jack
    It also has the RealTek* ALC662 audio codec which says:
    ALC662
    5.1 Channel High Definition Audio Codec
    General Description
    The ALC662 is a 5.1 Channel High Definition Audio Codec designed for Windows Vista desktop and mobile PCs. Its performance and functionality meet Microsoft Windows Vista (WLP 3.08) premium requirements. The ALC662 features three stereo DACs, two stereo ADCs, and legacy analog input to analog output mixing, to provide a fully-integrated audio solution for multimedia PC systems.
    All analog IO (except CD-IN and PCBEEP) are input and output capable, and three headphone amplifiers are also integrated to drive earphones on front (port-E and port-F) and rear panel (port-D).
    The ALC662 supports 16/20/24-bit S/PDIF output function and a sampling rate of up to 96kHz. It offers easy connection of PCs to high quality consumer electronic products such as digital decoders and speakers.
    The ALC662 supports host/soft audio from the Intel ICH series chipset, and also from any other HDA compatible audio controller. With EAX/Direct Sound 3D/I3DL2/A3D compatibility, and excellent software utilities like Karaoke mode, environment emulation, software equalizer, HRTF 3D positional audio, and optional Dolby® Digital Live, DTS® CONNECT™, and Dolby® Home Theater programs, the ALC662 provides an excellent home entertainment package and game experience for PC users.
    Features
    Hardware Features
    Meets performance requirements for Microsoft WLP 3.08 Vista premium and mobile PCs
    Six channel DAC supports 16/20/24-bit PCM format for 5.1 channel audio solution
    Two stereo ADC support 16/20-bit PCM format
    All DAC support independent 44.1k/48k/96kHz sample rate
    All ADC support independent 44.1k/48k/96kHz sample rate
    Supports 44.1k/48k/96kHz S/PDIF output
    All analog jack port are stereo input and output re-tasking
    Analog differential CD input
    Supports analog PCBEEP input
    Integrates digital BEEP generator
    Up to four channels of microphone array input are supported for AEC/BF application
    Supports legacy analog input to analog output mixer
    Built-in three headphone amplifiers for port-D (rear panel), port-E and port-F (front panel)
    Software selectable 2.5V and 3.2V reference output for microphone bias
    Software selectable boost gain (+10/+20/+30dB) for analog microphone input
    Two jack detection pins: each supports detection of up to 4 jacks
    Jack detection function is supported when device is in power down mode (D3)
    Supports two GPIO pins (general purpose input and output)
    Supports EAPD (external amplifier power down) control for external amplifier
    Support 1.5V~3.3V scalable I/O for HD Audio link
    Supports anti-pop mode when analog power AVDD is on and digital power is off
    48-pin LQFP ‘Green’ package
    Pin-to-pin compatible with ALC88x series, ALC660 series, and ALC26x series audio codecs
    Software Features
    Compatible with Windows Vista Premium (complies with Microsoft WLP 3.08 specifications)
    WaveRT-based audio function driver and logo ready for Windows Vista
    Direct Sound 3D™ compatible
    A3D™ compatible
    I3DL2 compatible
    HRTF 3D Positional Audio
    Friendly user interface for 2-foot or 10-foot remote control applications
    Emulation of 26 sound environments to enhance gaming experience
    10 Software Equalizer Bands
    Voice Cancellation and Key Shifting in Karaoke mode
    Windows Vista style configuration panel to improve user experience
    Microphone Acoustic Echo Cancellation (AEC), Noise Suppression (NS), and Beam Forming (BF) technology for voice application
    Features Dolby® Digital Live and DTS® CONNECT™ software (Optional)
    Features Dolby® Home Theater software (Optional)
    Applications
    Desktop and mobile multimedia PCs
    Information Appliances (IA)
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Sep 2006
    My application (realtek sound control app) has a subwoofer control. You might check the bios to see if there is an option to select the sound card mode. I'll get some more details on mine and post back.
    Feb 2007
    Using LF2 here.
    If you've enabled the six channel audio out in the soundcard app, check the mixer tab and the sub volume.
    GL!
    May 2006
    Calgary, Alberta
    Can I see some screenshots of where you enabled it and I'll see if I have that option on mine?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    Bump please. Trying to work on this in between everything else.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    Still struggling with this.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. M2-ATX with Intel Atom Motherboard Issues
    By jeremy480 in forum M2-ATX
    Last Post: 12-05-2010, 12:28 AM
  2. MTB-057 Intel D945GCLF Mini-ITX Motherboard OS Installation problems
    By Fiberoptic in forum MP3Car Products - store.mp3car.com
    Last Post: 07-08-2008, 01:50 PM
  3. Subwoofer Phase
    By IDOXLR8 in forum Car Audio
    Last Post: 10-27-2006, 11:34 PM
  4. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 12:00 AM
  5. Which Motherboard to Choose
    By james33440 in forum General Hardware Discussion
    Last Post: 06-07-2005, 10:35 PM
