Results 1 to 10 of 14
Thread: harddrive rack
    Jan 2009
    harddrive rack
    hi , i would like to know if is there any hard drive rack on the net ?
    i want it to fit in a cutom mdf box
    i have one 2.5 inch ssd
    and one 3.5 inch hdd
    thanks for the help .
    Low Bitrate Dexamenus's Avatar
    Nov 2008
    should be able to knock one up with wither some alloy tube or even some strips of rubber held tight to add some vibration protection
    Elsewhere
    Quote Originally Posted by Dexamenus View Post
    I agree that fabricating something for the HDDs is relatively easy.
    However, any "vibration protection" is not something I'd recommend.
    Mount your HDDs securely to your enclosure or to the chassis of the vehicle. Let the vehicle's suspension do its thing.
    How about the Wiki?
    Nov 2008
    Quote Originally Posted by DarquePervert View Post
    hmm, fair enough mate, what makes you say this though, i would have thought that 1) the suspension doesnt take you the small jolts that the hdd might suffer from, and 2) that extra protection wouldn't hurt?
    Elsewhere
    Search the forums.
    This is a subject that has been discussed, debated, argued, and mulled over repeatedly, with people knowledgable in the field weighing in.
    the general consensus is that vibration dampening for the HDD is more likely to keep the HDD vibrating and is actually more likely to cause damage.
    One user has had the same HDD survive two (three?) accidents, one of which totalled the car. The HDD still runs like a champ, and was never mounted to any vibration dampeners in any of the installs.
    How about the Wiki?
    Nov 2008
    Search the forums.
    righto mate, will do.
    cheers
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Search the forums.
    That would be me.... one of the wrecks bent a partially boxed full ladder truck frame. The computer parts are far more durable than you or the car.
    TruckinMP3
    Read the FAQ!
    Jan 2009
    thanks for the replie...but can we return the the rack :P?
    Jun 2002
    Colorado
    Quote Originally Posted by summer69guy View Post
    Make one from scratch, parts from an old PC case or find what you are looking for and buy it?
    I used a drive cage from an old desktop case. It was made to slide out, have hard drives attached then slide back into the case.
    This made it easy to remove from the donor case and it already fit the drives. It currently holds my DC to DC PS and one HD.
    TruckinMP3
    Read the FAQ!
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by TruckinMP3 View Post
    Big question though is where they full sized hard drives or shock protected laptop drives? Laptop drives are much better at taking large shocks.
    There are plenty of commercial harddrive enclosures...your best bet for mixed drives would be a dual slot 3.5" enclosure and then a 2.5" to 3.5" bracket for the second drive. Depending on your needs they should be only a few bucks on ebay.
    As far as vibration protection something like a rubber washer is about as much as you want to do...as was hinted at above strips of rubber can actually increase vibration (hence the reason cars have shocks and springs not just springs).
  1. Add an Extra Hard Drive
    By joesan in forum MacCar
    Last Post: 05-16-2007, 11:35 AM
  2. Brand New Hitachi Travelstar 5K120 80GB Hard Drive NIB
    By Jir1984 in forum Classified Archive
    Last Post: 02-19-2007, 11:20 PM
  3. FS: Hard Drives
    By adidas445 in forum Classified Archive
    Last Post: 01-10-2007, 04:18 PM
  4. My hard drive situation
    By PhatHam in forum Newbie
    Last Post: 10-26-2006, 01:50 PM
  5. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 09:50 PM
