Results 1 to 5 of 5
Thread: connecting car pc to head unit.
    Sep 2009
    Hi. I own a vrx868rvd and I have built myself a car computer to connect to the unit to use the screen (don't need touchscreen). The pc has s-video out which I can connect to video in (composite) but need to connect to sound. What is the 10pin connector on the back of the unit that the ipod connects to and can i get phono to this or will this take audio and video?
    Many thanks.
    Aug 2009
    Birmingham - UK
    Quote Originally Posted by mat14 View Post
    Many thanks.
    does the unit have a aux in ? - my stereo has got a 3.5 mm jack for aux in, the screen im looking at has 3 rca cables, 1 video, 1 left, 1 right
    most hu have 3 rca red, white, yellow - red n white being the audio...... depends tho
    Aug 2009
    Birmingham - UK
    http://www.caraudiocentre.co.uk/prod...vd_p-22476.htm
    from the looks, you need a 4 pole av cable
    its rca cable to av 4 pole 3.5mm jack. - i just bought one off ebay last night for laptop to rca for four quid...
    Jan 2008
    if your head unit supports video, than you will also be able to use the ipod connector for video(most don't). you shold be able to use the ipod connector pinout is very well documented, so finding the correct pins should not be a problem--the problem could be how your head unit switches to ipod input-- do you need to manually switch it, or does it detect that there is something plugged in?
    Sep 2009
    Thanks for all the suggestions. As the head unit didn't come with the phono inputs/outputs I scoured ebay and found a phono harness plug that fits to this stereo which will hopefully solve all my problems. If not sure I'll be back!
    Again, many thanks.
  1. Replies: 22
    Last Post: 12-17-2009, 07:21 PM
  2. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  3. Head unit and CAR PC
    By Cheekz185 in forum Car Audio
    Last Post: 03-17-2006, 10:46 AM
