Thanks, I just ordered one.
Now I have to figure out how to power my monitor w/o an inverter! I was using the P4 to output power to the monitor and bought the quick release power cable kit from this site in order to do just that.
that was just what i was going to recommend--- you will need the P4 cable--otherwise, the processor won't start up...
just so we are both on the same page, you mean the 4 pin connector that has 2 grounds and a 12 and 5 volt lead instead of 2 grounds and 2 12 volt leads?
usually, the rectangular 4 pin connector with both 12 & 5 volt power is refered to as a 4 pin molex connector, and the square 4 pin processor power connector is refered to as a p4, or processor power connector--just so your aware of it later on in case you need some help trouble shooting it any more
for your lack of power connectors, maybe something like this could help?: http://www.microbarn.com/details.aspx?rid=100071
