Green/Black - Rear Left Negative
Speaker lead
Green - Rear Left Positive Speaker
lead
White/Black - Front Left Negative
Speaker lead
White - Front Left Positive Speaker
lead
Purple/Black - Rear Right Negative
Speaker lead
Purple - Rear Right Positive Speaker
lead
Gray/Black - Front Right Negative
Speaker lead
Gray - Front Right Positive Speaker
lead
Light Green - Reverse Gear
Detection lead. This lead must be
connected for the G4 to switch
automatically to view the rear view
camera. This lead needs to see
+12v.
Orange/White - Illumination lead.
Wire this lead up to the illumination
wire on the car. This wire needs to
see +12 volts when the parking
lights of the car are activated.
Pink – Attenuator. This will cause
the
radio to mute when the cell
phone rings when used in
conjunction with a cell phone kit.
Currently this feature is nonfunctional.
Brown - Remocom - This is for
steering wheel control. An adapter
for the particular vehicle might be
needed. Currently this feature is
non-functional.
Blue - Antenna Turn On. If the
vehicle has a powered antenna (an
antenna that is motorized), this lead
will need to be hooked up. It will
cause the antenna in the car to
extend and retract when the radio is
accessed.
Light Blue - Hand Brake. This lead
needs to be wired up as a safety
feature. It will sense when the hand
brake is applied and will cause
certain features of the
software to be
enabled when engaged.
Blue/White -
Amplifier Turn On. This
lead is used to sent the remote turn
on signal to your amplifiers if you are
running any.
Red – Accessory. This wire must be
connected to an accessory wire
within the vehicle. This wire senses
when the ignition is turned on and
will cause a turn on and turn off
signal to be sent to the G4.
Yellow – Power. This wire must be
connected to the battery in the car.
Do NOT splice this wire into a wire of
a smaller gauge. Doing so will risk
the unit not operating properly and
could cause an electrical fire. If the
wire in the factory harness is the
EXACT same gauge as the wire on
the G4 harness, splicing into it will
suffice.
Black – Ground. This wire must be
suffice.
