Results 1 to 4 of 4
Thread: will this serve for a car pc?
    Mar 2008
    spain
    http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
    http://www.memorydepot.com/ssd_diskonmodule.asp
    Are they any good for replacing a regular SSD?, or regular 2.5 hdd?
    Citroen Xantia 2.0 110 bph
    Current Progress:
    planning - 80%
    buying - 90%
    mounting - 90%
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    It will work as an alternative. However, I don't suggest putting Windows XP on it. The device is too slow for practical purposes. If you don't mind waiting fifteen minutes or longer for your carpc to turn on, then it's ok.
    Mar 2008
    spain
    http://cgi.ebay.es/ws/eBayISAPI.dll?...=STRK:MEWAX:IT
    How about this one.Are CF cards speedy enough for Windows XP?
    And being able to deal with two cards it may speed up a little bit more, don't u think?
    Current Progress:
    planning - 80%
    buying - 90%
    mounting - 90%
    Oct 2007
    NO. Not quite there yet, but they are coming close to being capable. Bear in mind that the fastest Compact Flash cards are very expensive, and run approximately 30-35MB per second maximum throughput. If you were to raid0 two together, the read/write speeds will approach that of a typical mid range hard drive.
    So essentially, you're better off buying a VelociRaptor 10,000 rpm.
    If you want top speed without a spinning platter, use an solid state disk (SSD).
