Results 1 to 2 of 2
Thread: usb power from Jensen KSW41
    Oct 2009
    Question usb power from Jensen KSW41
    Hey all. I am a total newb, but I am wondering if it would be possible to get usb power from this unit:
    As you can see, there is a "DC 12V OUT", would it be possible somehow get a female usb port attached to this for power? I don't mind getting other adapters or whatever if they are needed.
    Thanks.
    Jan 2008
    it really depends on the internal parts-- if it somehow regulates the 12volts, than you could hook up a 12 volt hub to that port. but if it doesn't regulate any of it, than nothing will work with that.
    usb is regulated 5 volts so you would need something lse to get it to work properly
  1. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  2. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 10:50 AM
  3. Another USB standby idea: splice wire and use a relay?..need help
    By S4Per in forum General Hardware Discussion
    Last Post: 11-04-2006, 11:12 AM
  4. USB power issues - opinions please
    By zaxxon in forum Power Supplies
    Last Post: 07-20-2005, 11:03 PM
  5. Xenarc - USB Power cable?
    By Coeus in forum Power Supplies
    Last Post: 01-13-2005, 09:07 PM
