Results 1 to 2 of 2
Thread: M10000 CMOS battery every 3 weeks?
    Variable Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    My M10000 was great for about a year (got it second hand so longer thnn a year). The CMOS battery needs chaning every 3 weeks now, or more to the point I get an error message to says 'CMOS defaults being loaded....F1 to continue DEL for setup', so I end up changing the CMOS battery and re-setting the BIOS.
    Relevant other information. About the time I changed the CMOS battery the I tried hiberation in RR to see whether this would improve boot time, but didn't significantly, so went back to shutdown, as before. I also started using the interal USB header for more USB devices.
    I can't think why the CMOS battery appears to be draining so quickly and losing the BIOS settings? Any suggestions?
    Vauxhall Astra SXi Car PC installed.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    This one is tricky. Im assuming you are using new batteries each time. Is it very cold? Try resetting the BIOS using the jumpers before putting in a new battery. It could be that the motherboard has a short circuit somewhere, maybe try wiping down the motherboard and the battery connector? Do you see any corrosion? I suppose if nothing else works then you can strap on some AA's or have a regulated 3V supply direct from your main car battery.
  1. What kind of cap/amp?
    By asong31 in forum Car Audio
    Last Post: 12-26-2006, 02:30 PM
  2. 2nd Battery, Wiring Idea.
    By jmcclure22 in forum Newbie
    Last Post: 11-19-2006, 11:51 PM
  3. Replaced Motherboard battery now no post??
    By BADDERICK in forum General Hardware Discussion
    Last Post: 07-08-2005, 03:34 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. CMOS Battery Problem
    By grandamp3 in forum General Hardware Discussion
    Last Post: 04-07-2000, 07:06 PM
