Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Core 2 Duo vs. Core 2 Quad, what do you think.
  1. #11
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by HiJackZX1 View Post
    The setup does both. Each screen is technically shared between a personal PC and the main PC via a KVM switch. So on startup they all see the Main PC. Then if they do not want to do a shared task, they hit a button, it switches over on the KVM and they hit power to activate that unit. The main PC has to be on for the other units to do anything media wise. The front screen (driver screen) can only see nav, obd2, basically no media stuff. Then the passenger screens see all the media based stuff.
    How exactly does RAID work. I know that the new board I am getting, does support the option, but I have never understood how it works. Currently I have 2 hard drives on the main system, one 40GB drive, and one 150gb drive. The 150gb drive is split into 2 partitions, a 40GB one and a 110GB one. The 40 I use for HDD images.
    Well any raid you would use requires the disks to be the same size, otherwise its limited to the smaller disk. Raid is basically different methods of splitting and combining bytes to span multiple drives. In a car raid 0,raid 1, raid 0+1 or jbod would make the most sense. In your case I was recommending raid 1.
  2. #12
    _Dejan_'s Avatar
    Jul 2007
    I don't recommend you RAID0 Because if one HDD will fail you will lose all data... If you will put in raid1 40GB and 150GB you will have 40GB total space in raid array...
  3. #13
    Nov 2008
    i am running a dual core e8500 in mine without any problems at all
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Awesome new 3.5" board w/ C2D, DDR3, X4500, ALC888...
    By galvitron in forum General Hardware Discussion
    Last Post: 07-13-2009, 06:04 AM
  3. Core 2 Duo Confusion... Socket M/Socket P/Socket 479m for Jetway J9F2???
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 01-21-2008, 01:32 PM
