Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Cell Phone / RFID to turn on PC
    May 2009
    Blog Entries
    2
    I am not sure if this can be done or if there is already something out there to do it. I am thinking about an option to allow me to walk up to my car and the PC turns on. Essentially it would replace the ignition switch, giving a hot feed to the ignition line either using my phone as I walk up to it, or a separate keyfob on my keychain.
    My thought was this would speed up my time from getting to the car to it being up and running, as well as it would work as a valet switch essentially.
    Dec 2008
    why not install a remote car starter and have the pc work off that?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I've tried quite a few things over the years (as you can tell). I have a bluetooth module that I do experiments with and well, it's a bad idea. Detecting can't be done without connecting (excluding bluejacking hardware), so the BT can't be in use as you approach the car. Once it's connected to the car, no headset usage. It can disconnect when you turn the key though. Still quite a hassle. I also have a multi-handset cell-link home phone and handsfree in the car, so I just let those two auto-switch back and forth.
    Jan 2009
    Quote Originally Posted by obstacleman View Post
    Umm...why not just use S3 sleep mode on the PC?? It will turn on and be ready in about 2-3 seconds. By the time you're fastening your seatbelt.....
    May 2009
    Blog Entries
    2
    I dont think I was clear on what why I would do this. I actually have a few reasons.
    1. It would be cool to have it turn on before I got in.
    2. It would be an auto on valet switch(I am in DC with lots of valet garages)
    3. I dont have to have it use the cell phone, maybe an rfid type sensor.
    4. I would like to have it keep the pc on even if I need to step out for a 5 or 10 minute time frame. We have tandem parking so sometimes I start it move it, have to turn the car off, then back on again 3 minutes later after moving the other car.
    Mar 2004
    Florence Yall, BFKY
    Sounds like what I sell (shameless plug). The idea is to leave it on or off when I think about it, which is when I'm already out of the car and then I forget it's on so it has a timer.
    RFID DIY projects get expensive. There's the less than an inch away type (RFID), the baby finder type radios that are unreliable, and the fobs like Cadillac/Corvette type things. Those might be what you want, but good luck trying to source that stuff.
    Another option a lot of users do is just use a switch in the car for on-auto-valet.
    May 2009
    Blog Entries
    2
    Your timer units look interesting. Will any of them work that I would wire it into my keyless entry - it is oem. That would be pretty handy.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Doing this with bluetooth is easy if your don't mind the hardware involved. You would need a computer (or microcontroller with bluetooth) running all the time scanning for cell phone in range. You can then check signal strength to determine when the phone is close enough to start everything up, but depending on your phone results can vary based on battery level, other bluetooth devices in the area, etc.
    Mar 2004
    Florence Yall, BFKY
    Yes, the second one down works with OEM or aftermarket alarms. 1 input toggle or 2 input on/off. Lots of other options. You have to wire it to the locks though, and it has a non-remote button disable/valet/keyless-on/keyoff-stay on, so it's a lot less remote controlled, but gets the job done. I think some newer PSUs have a remote input built-in though?
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    I have a small cpu system that is always on. It detects when the central lock is activated (acctually my specific key :-))
    The cpu system then activates the normal standard on-off button, whatever that is configured to do. (standby/hibernate/boot)
    It will also shutdown/hibernate/standby the PC after a configurable timout when ignition is turned off.
    Work quite well, and saves me about 7s of valueable boot time.
  1. Replies: 8
    Last Post: 03-31-2009, 04:06 PM
