Results 1 to 7 of 7
Thread: Inverter question in regard to backlights
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Is it posible to fry an inverter if the backlight does not match or was NOT made for the specific inverter?
    I ask because I would like to get another backlight for my setup, but it has been really dificult. I have noticed its easier for me to find an actual screen than find the backlight.
    Plz shed some light on the subject.
    Jun 2002
    Albany, NY
    Nope, frying the inverter should not be a concern. However, you may find it difficult to physically install a backlight that was not made specifically for your display.
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    what kind of screen do you need a back light for?
    we have several in stock,
    Feb 2003
    South Florida
    I need a backlight for a Sharp LQ10D361. if you got let me know. Although it will be in a couple of weeks, because I just ordered a Sharp LQ10DX01 from Ebay. So if the one off this screen does not work I will definatly order from you.
    M with the info, or post away.
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    As long as the replacement backlight it rougly the same size and brightness, you should not have a problem with the inverter.
    I recall having seen CCFL tubes in the Digikey catalog. Maybe they have something suitable for you?
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
    Feb 2003
    South Florida
    I tried them and they reffered me to JKL. Still no joy.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Some people here said they've used the ones from All Electronics
    It's under Lamps>Flourescent
    You can find the appropriate length tube there and it may work - and they're cheap!
    - Jeff
