Results 1 to 8 of 8
Thread: Mini-ITX in a DIN case and mini-itx Q's
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    I was toying around some looking at MB's and such rethinking my current setup. Looks to me like a Mini-ITX board will fint insinde a DIN opening (2"x7"). Anyone tried it for sure, I mean fit the whole thing in one box that fits in a DIN size? Alos is mini-ITX a standard or only available from VIA? If its a standard are there other companies that make MB's, if not does the VIA chipset product good sound like my Intel FlexATX board?
    Mar 2003
    NJ
    Here is an example of a Mini-ITX board in a DIN size case:
    http://www.checkercube.com/store/c134.html
    I've seen a few custom mini-itx cases here that manage to squeeze the system into an old radio. I can't remember the specifics though.
    There are a few other manufacturers making ITX or similar sized MBs. You can do a quick Google search for more details.
    Feb 2002
    Ontario, Canada
    check out this one RUNDIG . Keep in mind you'll need space behind the whole unit for all your cables attached to the motherboard, they'll add a least 3 inches to the depth so make sure you have a deep dash.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
    Jun 2001
    Boise, ID (USA)
    Holy crap that guy has WAY too much time on his hands... That is sweet...
    May 2002
    Ohio
    I'm thinking of doing something similar. I keep thinking of ways to shrink all my stuff so I can fit more
    Apr 2003
    Minnesota
    I think it'd be cool to have it in an old NES shell...
    BTW, anyone know if the Epia boards (any or all) offer tv-out, so I don't have to buy a TV card?
    Feb 2001
    Somerville, MA
    The M 9000 definitely does. I think the 10000 does as well.
    Twostep
    Apr 2003
    Minnesota
    Twostep
    Thanks, I was planning on getting the TM-701L (7" Widescreen LCD w/TSK), but I've heard about resolution problems (not being able to change it, etc...) on the Epia boards. Would I be able to use the onboard video out directly to the LCD, and have it displayed correctly? Also, does the LCD controller (touch controller, whatever it's called) require a PCI slot? I know the Epia's only have one and I don't want to be screwed on expandability.
    (sorry to steer this thread off course...)
