Results 1 to 3 of 3
Thread: Hibernation issue
    Newbie koll48's Avatar
    Aug 2007
    NC
    Hibernation issue
    I have my carPC going to hibernation on key turn and often (75% of the time) when i start it back up the a screen stating: cannot boot from last saved session choose to delete last saved session or restart and try again.
    Has anyone had this problem and how did you fix it. I believe that this is a sign of some temporary hardware failure which will probably become permanent over time.
    thx
    Elsewhere
    I've seen this happen when the OS hangs on something when attempting to go into hibernation.
    The most common cause of a hang that I have experienced is an active bluetooth connection. It is certainly not the only potential cause.
    Doing a full reboot every so often helps prevent hangsing on hibernation.
    Again, this is based on my personal experience.
    How about the Wiki?
    Jun 2008
    Seattle, WA
    Is your power supply timer set too short? For example, is it killing all power to the computer after 45 seconds, but it takes 60 seconds for your computer to hibernate?
  1. XPort/BU-353 hibernation
    By MastaKebob in forum GPS
    Last Post: 03-07-2008, 02:12 AM
  2. Hibernation drawing too much power...
    By Borte in forum General Hardware Discussion
    Last Post: 09-06-2006, 09:03 AM
  3. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  4. I'v had a thought! - Make Hibernation Better?
    By mick-uk in forum WinNT Based
    Last Post: 05-19-2005, 09:39 AM
  5. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
Tags for this Thread
