Results 1 to 6 of 6
Thread: Trying to extend a usb cable
    Newbie migitcheetah's Avatar
    Mar 2008
    OR
    im trying to make/extend a usb cable that has the mother board pins on the one end, and a female usb A on the other. im trying to hook up a portable hdd to transfer movies and music and such while on the go, but the hdd has the software and such that wont be recognized unless pluged into a usb that is directly pluged to the mother board. ive tried extensions and hubs.. never a powered hub, but i figure its the same deal considering the extension is just an extra wire tha tsuplies the same conection.(i hope thats rite)
    but i already got wire and hooked it up red to red, black to black, green to green, and white to white. and when i plug the hdd in it turns on i see the light, but the computer still does not recognize it. i plugged it into the shorter usb end and it pops right up. i pluged my psp into the extended one and it pops right up. but the hdd nothing. does anyone know how i could solve this problem.
    My name is Ryan and im a CarPC....
    Check out my post 94 Cadillac Seville
    If your in Oregon hit me up. lets get a meet going. or let me know of any.
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    How long are you trying to make the cable. There is a limit of 5 meters, or 16' 5" due to timing and echo issues.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    Sep 2009
    Australia
    If I read you correctly you have never tried a powered hub and the HDD you are using is powered via the USB lead. If not then ignore the following.
    There are a number of motherboards with USB ports that will not or only marginally power a HDD from USB socket. Changing the length of the USB lead will make all the difference; short one works, slightly longer, no go. Either make a heavy duty USB cable or use a powered hub with a short lead from the hub to the drive. Powered hub is the preferred method.
    Mar 2008
    OR
    no I have not tried a powered hub yet, the problem is that my pc is in the trunk and I want the hdd to plug in the front next to the driver seat... so I need tooo have the hub/cable reach 15ft.
    How would ii make a heavy duty cable, or if I hook the powered hub to an extension will it still work.
    Constant Bitrate leo_bergamo's Avatar
    Apr 2009
    Cat5
    I installed my car computer in a full size van. So the display sits on top of the dog house and the PC itself is installed under the rear-most bench seat. My point, I ran into the problem of wires and cables comming up too short and I have used old lengths of CAT5 to splice into the USB cables etc. I have not had a problem since. Hope this may help...
    Sep 2009
    Australia
    Quote Originally Posted by migitcheetah View Post
    so I need tooo have the hub/cable reach 15ft. How would ii make a heavy duty cable, or if I hook the powered hub to an extension will it still work.
    Your main problem is powering the HDD from USB, run your lead and put a powered hub at the end next to the HDD. There are powered HUB's around for 12v Car installs. It should work with a good quality USB lead at 15ft.
    You could of also try an SSD or a really low power HDD, some work better thn others. Some external USB HDD's also have a seperate power input to overcome USB power problems when they crop up.
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 01:26 PM
  2. Replies: 0
    Last Post: 06-27-2009, 07:59 PM
  3. USB cable or hub with cover/cap?
    By Mikey-Z in forum Input Devices
    Last Post: 01-12-2009, 01:36 PM
  4. Lillput USB problems
    By the_big_1 in forum LCD/Display
    Last Post: 11-22-2008, 12:00 PM
  5. Transfering Files with USB cable or Ethernet Cable
    By aamrtin_723 in forum General Hardware Discussion
    Last Post: 02-12-2006, 07:36 AM
