Results 1 to 8 of 8
Thread: Video Output Problem
    Aug 2009
    Hi, I recently encountered a problem with my CarPC and the monitor (Lillyput 7" Touchscreen) no longer shows any signal coming from my motherboard. At first I thought it was just a motherboard problem, so I sent it in and had it replaced by warranty replacement. Yesterday, excited to get the CarPC up and running again, I set it all up and have the same problem. I have tested the monitor on a laptop and it works flawlessly...so I know it is not the monitor, but what else could it be if the motherboard has been replaced and still has the problem? Is it possible that the power supply isn't giving enough power to the motherboard to power the integrated graphics?
    Here is the hardware:
    180W DC-DC ATX/BTX
    http://www.opussolutions.com/index.php?p=product&id=56
    Lilliput Eby701-np/c/t Lilliput Eby701-np/c/t
    https://www.amazon.com/gp/product/B0...ss_T15_product
    Intel D945GCLF
    http://www.intel.com/Products/Deskto...F-overview.htm
    All help and input is appreciated, thanks!
    Jan 2008
    have you made sure to connect the 4 pin processor power connector?
    have you tried different memory?
    Aug 2009
    I have made sure the 4pin power from the power supply was indeed plugged into the motherboard, but I will try to get my hands on some different RAM tonight and see how that works. Thanks
    Aug 2009
    sadly, that did not fix the problem. I am leaning towards a faulty power supply...does that make sense as to why the video output is not detected? It seems like the only piece of hardware that could be causing the problem. Also, when I plug in a ps2 keyboard, the numlock/capslock/scroll lock lights won't come on, also making me lean towards the power supply.
    Jan 2008
    that was my next suggestion-- see if you can control the number lock light after the system turns on--- a sign that the computer has at least gone through POST.
    being that you can't, try removing all the devices from the motherboard, especially any pci cards that you might have plugged in(i had a floppy pci extender that didn't allow my sytem to boot).
    you could also try a AC power supply that you know is working properly.
    Aug 2009
    Thanks, I have removed all extra components from the motherboard, but no luck I will try to get my hands on an AC power supply this weekend and make sure that it is indeed the power supply. A little off topic I supposed, but has anyone used/heard about this board?
    M4-ATX 250W Intelligent DC-DC PSU
    http://store.mp3car.com/M4_ATX_250W_..._p/pwr-031.htm
    Probably going to order that tomorrow once I am positive it is indeed the power supply that is causing all of this trouble! Thanks again
    Aug 2009
    I got a chance to try out an AC power supply today and that was indeed the problem. Ordering this tomorrow:
    http://store.mp3car.com/M2_ATX_160W_..._p/pwr-015.htm
    Aug 2009
    Quote Originally Posted by reblis View Post
    Finally ordered that part, was very excited to get it installed, and I still have the same problem. I have used a voltage meter to test the battery voltages and they seem to be fine. I have already replaced the motherboard, RAM, and power supply, not sure what else there is to replace. Any helps would be GREATLY appreciated, thanks
    EDIT: Also tested the monitor on a laptop, works fine
  1. Weird video interference problem! HELP!
    By lookinco in forum LCD/Display
    Last Post: 03-18-2011, 07:10 PM
  2. Xenarc 1020TSV Video Noise Ground Problem
    By bblitz in forum LCD/Display
    Last Post: 06-14-2008, 02:02 PM
  3. Video Output Options
    By txspazz in forum General Hardware Discussion
    Last Post: 05-22-2008, 06:22 PM
  4. Help wt. Video Output.
    By grnLude in forum LCD/Display
    Last Post: 01-09-2007, 06:06 PM
