Results 1 to 2 of 2
Thread: Micro controller
    Nov 2001
    Micro controller
    does any one know how to program any micro controller??
    i need it to do the following with the new xenarc screen:
    there would be three buttons connected to the micro controller
    - if button 1 is pressed i need the micro controller to change from whatever input it is showing to the default PC input, but if it is showing already PC input do nothing
    - if button 2 is pressed i need the micro controller to change from whatever input it is showing to input 1, but if it is showing already input 1 do nothing
    - if button 3 is pressed i need the micro controller to change whatever input it is showing to input 2, but if it is showing already input 2 do nothing
    also does anyone know how to switch between 2 sound sources going to an Amplifier, eg.
    if button 1 is pressed it will let PC sound enter the Amplifier
    if button 2 is pressed it will let PC sound also enter the Amplifier
    if button 3 is pressed it will let another sound source enter the Amplifier
    Thank you
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    Sounds like an AV switchbox to me,
    like this: http://www.partsexpress.com/pe/pshow...=180-932&DID=7
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
