Results 1 to 7 of 7
Thread: 06 Infiniti M35 back up camera
    Nov 2009
    My car came with the nav system but not the reverse camera. Im looking into adding it myself and was hoping somebody could confirm whether it's possible to do
    I manage and auto shop so i have access to a lot of the tech data that i need , what im not sure about is whether the oe equipment is plug and play. After taking apart the trunk , it seems that it came pre-wired for it as there are unattached wire harnesses ending at the spot where the camera controller would be. The steering column already has the steering angle sensor in it , so i think all i need (and have found) is the oe camera and control module
    Any opinions?
    Nov 2009
    Well if nobody knows , i did see some nice alternatives to the OE camera in the mp3car store. Has anybody tried using the lilliput as a camera display ?
    Constant Bitrate vull's Avatar
    Oct 2007
    how expensive would the OE camera be if everything is already pre-wired?
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    $150 on ebay?
    I've used the Xenarc to display my stock OEM back up camera once, it works fine. Where do you plan to fit the lilliput?
    Nov 2009
    I can get the oe camera and module for $250 locally. If i try the liliput im thinking of putting it where the sunglass holder is , gonna take a bit of modifying tho to make it fit and drop down
    Dec 2007
    Danville, CA
    Quote Originally Posted by PalmBeachBoxer View Post
    That's what I did with my FX, you may want to check my sig.
    Nov 2009
    Quote Originally Posted by RipplingHurst View Post
    Nice! Thx for the blueprint , i was initially thikning of hinging it so it would hide away but that would be a lot of work and seeing how nice yours came out i think it wouldnt be worth it
  1. Infrared night vision camera review. Sold by MP3Car.
    By nobb in forum The Review Palace
    Last Post: 03-23-2010, 07:56 PM
  2. XM Direct protocol, Need help with commands !!!
    By Cinfraco in forum Car Audio
    Last Post: 07-28-2007, 06:10 AM
  3. Back Up camera
    By Super_dave in forum Input Devices
    Last Post: 11-18-2006, 05:21 PM
  4. Replies: 10
    Last Post: 07-28-2005, 03:29 PM
