Results 1 to 5 of 5
Thread: USB Hubs / Powered or not
    Mar 2003
    Orange, CA
    What's the determining factor if you need a hub with it's own power source or not?
    I'm confusing myself trying to figure this one out.
    Car: 2003 Nissan 350Z
    Installed: Epia M9000, Casetronics 2699R Case, Crucial 256mb DDR, Maxtor 60gb 3.5" HD, Toshiba Slim DVD, Pioneer 3.5" Slot DVD, Gyration RF Keyboard/Mouse, Deluo GPS Receiver, Windows XP Pro, D-Link 2.4ghz usb wireless adaptor.
    Pending: 6.4" LG Phillips VGA Touchscreen, some type of alternate/additional power supply, Audio Connection
    Aug 1999
    Washington D.C.
    It depends on the load of the devices plugged into the hub. From my personal experience, I never seemed to be able to get away with not powering the hub. The USB spec doesn't allow for much.
    Mar 2003
    NJ
    Power requirements
    You can use the Device Manager in Windows XP or 2000 to look at how much power is being drawn by your USB devices.
    1) Open Device Manger
    2) Expand your entry for USB controllers.
    3) Right-click on USB root hub, then select Properties.
    4) Select the Power tab.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    High powered device = 500ma, low powered device = 100ma. The root hub provides upto 500ma to a port, so that 500ma is availible to how ever many things you would plug into your unpowered hub. If you're just going to connect a keyboard and a mouse, that would be fine, but if you're wanting to connect a wifi usb adapter, a usb digicam, etc, an unpowered hub wont cut it.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Jul 2005
    NJ
    Quote Originally Posted by MP3DUB
    if you have a self powered hub...would it draw too much power once the carcomputer is turned off?..or aslong as the carcomputer is off and all of the devices (except for the GPS) are of is it ok?
