I've got some findings to share that perhaps you can try to figure out if your power supply is even the culprit. I ran with the E8400 and then installed my E7200 and ran it at different clock frequencies with the last test being at minimum vcore that I can get (no undervolting by BIOS options).
Idle consists of no activity immediately after running some type of test off of the platter based HDD. Load runs INtel Burn Test and ATI Tool, both apps which cause the maximum power consumption and heat generation on my main PC. The graphics do not really impact the power consumption (<100mA), even when changing the processor priority of IBT. All devices still attached as above. All measurements taken from my shunt ammeter and clamp ammeter for consistency. Power taken off of my Stinger SPS60 power supply (13.8v output at <60A).
E8400
idle @2.00GHz 1.175v 1.8A
load @3.00GHz 1.225v 4.6A
E7200
idle @2.00GHz 1.15v 1.6A
load @3.13GHz 1.20v 4.4A
E7200
idle @1.60GHz 1.15v 1.6A
load @2.53GHz 1.20v 4.0A
E7200
idle @1.20GHz 1.15v 1.5A
load @1.90GHz 1.20v 3.5A
E7200
load @1.90GHz 1.15v 3.3A (RMClock)
You can save 1 amp, likely most or all on the 12v rail, by underclocking about 1/3 of the cpu's max frequency. Obviously this is on my system only but these figured should be similar enough across the board for percentages of frequency drops without voltage changes. The above numbers equate to ~3.6A MAX draw on 12v at 1.9GHz/1.15v if no other voltage rails were being used (3.3A input * 13.8v input = 45.54 * 0.95 efficiency / 12v output = 3.6A). I can't see how your X3 could be any worse.
It is nice to see a 45 degrees Celsius load temperature with the 1.9/1.15v though, with a low profile heatsinkToo bad the motherboard is stupid and can't automatically control the fan, although it's PWM and I can control it in the BIOS by manually setting the speed.
LinkBack URL
About LinkBacks
). With the above system, at 3GHz and stock 1.175v VID, it draws 5.2A at 12.1v from the
