Results 1 to 2 of 2
Thread: Lilliput not powering up?..
    Nov 2009
    Hey guys, I'm kinda new to the whole CarPC game but I'm trying to get my lilliput 7" LCD Touchscreen to power up. I plugged my lilliput into my PC without a power supply, and my computer detects it just fine. I tried plugging in a constant 12v (positive in the inside/negative on the outside barrel) and nothing lights up nor does the screen turn on. Any clues to what could have happened?
    I took a multimeter and put it on the fuse on the circuit board and it's sending a constant 12v just fine. Anything else I should test?
    I tried
    Nothing seems to be burnt?..
    Jan 2008
    it might be a backlight.
    i know that my lilli 629 will only send touch screen commands after it is powered on(not just having 12 volts connected).
    try looking at the display while it is powered on and connected to a computer to se if you can see the 'ghost' of a image on the screen.
  1. Powering your lilliput
    By stangg172006 in forum LCD/Display
    Last Post: 02-10-2007, 08:13 PM
  2. Powering Lilliput.
    By bimmeracer in forum General Hardware Discussion
    Last Post: 01-03-2006, 04:17 AM
  3. powering lilliput lcd from opus psu .
    By robutek in forum Power Supplies
    Last Post: 06-13-2004, 03:51 PM
  4. powering up a lilliput thru a regulator
    By masch in forum LCD/Display
    Last Post: 01-25-2004, 02:57 AM
  5. Powering Lilliput
    By telstargb in forum Power Supplies
    Last Post: 01-20-2004, 08:01 AM
