Cut the blue wire. That timer is meant for a pulse input, but you're giving it a switched input so it's detecting the transition from high to low as the end of a positive pulse.
hi, my question is how can I activate this relay with ignition.
Here is what I did.
I connect first Black/Stripe (Trigger) to my ignition line. Then I connect black to ground, yellow and brown to my device a laptop pwr switch. I then cut the blue loop for a positive pulse (uncut for negative pulse). Then lastly red to constant (I dont know if I even need this)? My problem is when I turn on the car relay does nothing when is off it gets energized. What I think I need to do is somehow connect ground to the switch??? for a negative pulse. Anyone who can help? thanks
Dei 528T Pinout/wiring:
My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
