Results 1 to 10 of 10
Thread: Intel D945GCLF2 + M2-ATX workbench setup
    Jul 2008
    Hello!
    I'm trying to setup a home workbench with a M2-ATX PSU + intel D, connected to a 12v AC/DC Adaptor.
    The ignition wire is connected to the + wire.
    It happens that the board activetes the led but, when I press the power button, it spins the fan and goes off... I've already tried with the power connector connected to the M2-ATX, also with the same results...
    My adaptor is drawing 2.45A... would this be the cause? How much amperage is needed to power up this MB?
    I have a spare ATX which draws 20A max... since the M2-ATX has a 15A fuse I didn't find that wise to use it... Am I right?
    Thank you for the help!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Does the MB operate correctly with a known good desktop Power Supply?
    That will tell you if it is power or MB....
    TruckinMP3
    Read the FAQ!
    Jul 2008
    Yap.
    If I bypass the M2-ATX and connect my spare ATX power supply directly to the motherboard it works nice like a regukar pc...
    That's what i'm doing right now for software testing...
    I'm asking this because I'd like to test the M2-ATX itself...
    Thx!
    Low Bitrate Dexamenus's Avatar
    Nov 2008
    remove all the jumpers on the psu and then just connect the 12v from the adapter to the 12v pin, and the ground to ground, leave the ignition disconnected
    Jul 2008
    Thank you for the advice!
    It happens the same thing...
    I got the MB led on but when i press POWER the fan spins and stop right away... the board never gets to POST...
    So the intensity isn't that much important right? Then what can it be? PSU's fault?
    Thank you for the help so far!
    Jan 2008
    try unplugging the ram, and powering it up-- if the ram is bad it might not be letting it post(it won't post without ram, but will turn on and stay running)...
    otherwise, in rare cases, it could be a faulty processor-- you can try unplugging the p4 cable(you remembered to use that 4 pin pentium adapter right?), and it should power up, and stay running, it just won't post.
    Jul 2008
    Tried both... same happening... (and I didn't forget the P4 cable )
    I wasn't expecting problems with the ram or processor, because the whole pc (motherboard+components) works perfectly using a regular ATX power supply...
    Low Bitrate RonsRed88's Avatar
    Aug 2009
    Western Washington State
    Are you using the M2 to also start the motherboard (using the two pin cable)? My M4 was acting similarily and it turned out that it was basically holding the power switch on. Try disconnecting the power switch cable and start the motherboard using another switch or just by jumping the two pins together with a screwdriver. If it's the same problem I had, the motherboard will run just fine.
    Ron
    Dec 2006
    Quote Originally Posted by RonsRed88 View Post
    Ron
    I have the same problem as RonsRed88 with my M4, and had to just jump the 2 pins. But when I hook it up in the car it works find.
    Dec 2009
    I noticed the fan start and shut down with two different units and quickly figured out there was not enough current. The wall adapter was 1000 milliamps, but a portable battery worked fine. I ended up using a 24V/1.75 amp charger which powers the device fine for testing.
  1. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  2. Xbox w/ M2 ATX and PSU convertor
    By MiniRX7 in forum Power Supplies
    Last Post: 11-25-2007, 07:45 AM
  3. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
  4. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 06:22 AM
  5. Replies: 15
    Last Post: 06-24-2004, 10:49 AM
