Results 11 to 20 of 23
Thread: Computer and amps not turning on, very temperamental.
  1. #11
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    any of the car audio shops should have 4ga cable.
    where are you (UK is a big place)
    MacMini in an Alfa? - Why not!
  2. #12
    May 2009
    Hampshire, England
    I'm gonna order it online anyways, but Hampshire/Berkshire way.
    Is 4ga enough? I was thinking I would have to go for 2 or bigger XD
    Car: Ford Focus
    Currently stock setup. Trying to decide on the best setup for me.
  3. #13
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    For Kenwood KAC-9104D, the current is 55A, so depending on the length of the wire,
    you will need 2-5 AWG cable, and a 80-125A fuse, just for that amp.
    You can start there here, or
    you can check EMMA wiring recommendations.
    Imho: use 0awg on big three, 2awg to sub amp, better safe than sorry
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
  4. #14
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Here's a great place to fill any of your wiring needs:
    http://www.darvex.com/power_wire.html
  5. #15
    May 2009
    Hampshire, England
    Quote Originally Posted by simplex View Post
    Dam, basically this is my setup.
    *************************************************> 30A fuse > 8awg cable > amp
    Battery > 200A fuse > 4awg cable > fuse distribution box > 30A fuse > 8awg Cable > amp
    *************************************************> 30A fuse > 8awg cable > m4-atx
    o and 4awg cable goes from battery to trunk.
    Car: Ford Focus
  6. #16
    May 2009
    Hampshire, England
    Quote Originally Posted by djvillar View Post
    that place is good, but do they ship to UK =P
    I should also mention that my system was working fine and dandy for a month before this happened =S
    Car: Ford Focus
  7. #17
    May 2009
    Hampshire, England
    latest update on how broken my car is >_>.
    Today on the way back home from work, engine cut out after i dropped the clutch coming up to a roundabout and power steering went with it (and I shat my pants). Also pulling into my drive.
    Just curious, what cables and fuses would you use for my setup?
    Gonna re-ground everything hopefully Tuesday/Wednesday, but I don't think that's the problem anymore =(
    Car: Ford Focus
  8. #18
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    OK. Let's quit beating around the bush. I think it's the alternator. When you drop the clutch, the engine goes back to idle, so it sounds to me like the alternator isn't putting out enough juice @ idle, causing the car to die. It also might be a loose wire in some obscure place. I had a similar issue with my Turtle shortly after I got it, but it doesn't have power steering to begin with, so I didn't shat my pants until I had to push it up a hill in rush hour traffic...
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
  9. #19
    May 2009
    Hampshire, England
    Haha, the reason I was beating around the bush was because that part is more expensive than a battery =(. Also I know jack all about em and where to get em and what to look for and if there universal etc =(. let's hope my dad knows more lol
    Car: Ford Focus
  10. #20
    Elsewhere
    If the alternator AND the power steering went out, it sounds like you could need a new belt, assuming both the alternator and the power steering pump are ont eh same belt.
    I don't know your car, but that's a possibility.
    Granted, it doesn't rule out the need to do a Big Three upgrade or a failing alternator.
    How about the Wiki?
  1. M1-ATX not timing, not turning on PC
    By sYx66 in forum Power Supplies
    Last Post: 02-20-2006, 10:13 AM
  2. Amps Protecting at high volumes
    By kdunn926 in forum Car Audio
    Last Post: 08-30-2005, 10:14 PM
  3. Amps power up AFTER computer is on and still pops
    By Ascension in forum Car Audio
    Last Post: 07-16-2005, 03:24 AM
  4. Replies: 13
    Last Post: 04-15-2005, 03:55 PM
  5. Anyone running their computer AND amps off the Opus?
    By brrman in forum Power Supplies
    Last Post: 12-09-2003, 02:30 AM
Tags for this Thread
