Results 1 to 10 of 12
Thread: psuedo start up controller, help :)
    Hosting Guru
    Oct 2001
    Atlanta, GA
    ok... this may need to be moved to power supplies but we'll see...
    First let me say what hardware I have:
    -Dell Inspiron 8000 Laptop (850Mhz pIII, 256ram, 40g, dvd, sans lcd... picked it up cheap on ebay)
    -7" in dash touch lcd (well, will have as soon as DigitalWW sells em)
    -JVC Kameleon LX-50 head unit (aux input)
    -Power will be supplied by a dell car adaptor unit.... its really just a regulated dc -> dc supply so no biggie here I've got everything powered up and it works fine.
    Ok, here is how I would like the system to work I've got the "basics" covered but need a little help designing the circut... I know it won't be complex but still need a little help
    Basically I want a relay that sits on the remote ("amp") on line from the head unit that when powered turns on the 12v to the DC adaptor for the laptop and somehow activates a momentary switch to turn on the laptop. Then when the car (or head unit) is turned off the relay will disengage and the dc adaptor will turn off.
    ----------- already have this party done -----------
    then when the laptop goes from "DC" to battery power it will auto hibernate after 20 min of battery power.
    I know the relay for the dc adaptor will be easy... I think the only hard part will be getting it to somehow activate a momentary switch or I can hard wire the switch and somehow just have something complete the circut for a minimal amount of time... I don't know really thats why I'm looking for help...
    thanks!
    -- WireSix, Inc. --
    MP3Car Lives Here!
    Hosting Guru
    Oct 2001
    Atlanta, GA
    *bump*
    -- WireSix, Inc. --
    MP3Car Lives Here!
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Give this a try:
    When you apply 12v, the capacitor "acts" like a short, bypassing the resistor and energizing the relay. The C and NO contacts will be on for a time determined by the resistor/capacitor values. When the capacitor is fully charged, the relay will be turned off (even with power applied to it).
    This resistor/capacitor combination will give you approx. 1/2 second. Increase the capacitor value to increase the on time.
    When you remove power, the cap will discharged through the resistor.
    The capacitor should be rated at min. 25 volts.
    Maximum Bitrate none's Avatar
    Sep 2003
    Can somebody please repost this circuit? It seems to have disappeared and I need it!
    Quote Originally Posted by mp3hombre
    Give this a try:
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    bump
    Newbie z28control's Avatar
    Oct 2003
    Houston, TX
    If you want to use something simple and pre-packaged, for ~$40(US) this might be a good solution.
    PTR-7
    It seems to have a lot of flexibility for custom ON/Off, timed, and pulse functions. Option 12 is probably your best bet. (Table in the .pdf file)
    Possible sources:
    One
    Two
    Car PC - If you have to ask why, you'll never understand.
    XAA289.com
    Apr 2003
    Brooklyn, NY
    Here's the stupid question, i have a Dell Inspiron too but a 2500... How do you get the laptop to turn on without opening the laptop and pushing the power button? On my bookpc i had a option of resume on AC loss but on the laptop i don't have that function... ANy suggestions?
    Possible sources:
    One
    Two[/QUOTE]
    1997 Mazda 626 ES [Cronos] - 2.5L V6
    http://www.cardomain.com/id/hmany2k
    Jun 2002
    Anyone have anything on their laptops called wake on ring? I have it on my laptop. It looks at the RI line of the serial port. You provide 12v to it and the computer powers up. Take a look in your bios for it. If you have it let me know and I'll help you figure it all out.
    Tom
    1993 Probe GT
    Rio Car w/20gb
    Apr 2003
    Brooklyn, NY
    Nope can't say i have that either... Any other suggestions =(
    Quote Originally Posted by tbdombrosky
    Tom
    Nov 2003
    Chicago
    Here's my $0.02. I've got an old laptop installed in the dash that I semi-permanently have the power button fastened in the down position. This allows it to power up when power is applied to the dc-dc car adapter and power down when the power is cut.
    Some laptop power supplies will reset if the power button is held down...luckily mine doesn't...otherwise this literally $0.10 idea would not work.
    I running win98se with the scandisk off and with a couple hundred ungraceful shutdowns it has yet to corrupt.
