Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Intel x25-m SSD - has anyone tested it in cold?
  1. #11
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Although my OCZ Summit drops from 100+ MB/s to 7MB/s in the cold, the only thing you really notice is that hibernation and boot takes longer. The general "snappyness" of the OS as far as folders opening up, multitasking whatnot...you can't really feel. So yea, I guess we can't make any definitive conclusions about the Vertex just yet.
  2. #12
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Outside -7C and carpc boot perfectly without any slow down...
  3. #13
    Feb 2008
    OK guys, many thanks for your postings here.
    Ordered x25-m g2 today, should have it by the evening already. Will post how it works at -20C (now its its -18C in moscow).
    By the way on russian carpc forums I got a confirmation that x25-e worked last days ok (it was -20 to -26C) which sounds promising as the controller is the same. On the other side memory chips themselves may influence working in cold (SLC Samsung in x25-e vs MLC something in x25-m)....
  4. #14
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    ugh, haven't thought about the cold.
    -C temps ...
    Moisture developing from the heat changes will cause problems. You might want to think of some kind of insulation for your unit.
  5. #15
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by leman View Post
    Did you test it?
    Today has been -8C and still normaly work. I hope that we will get little lower temp. that I can test it more...
    Also I have G1 version which is build in 50nm and you have G2 which is 34nm, so maybe there will be some diference in cold operation...
  6. #16
    Feb 2008
    Dejan
    Nope, I got it but did not manage to install yet, hopefully will do tomorrow.
    SapproGuy
    Condensate is theoretically and issue, however since more heat-consuming parts tend to sweat the most you would be OK if you have massive metallic case (e.g. voompc) and good ventilation inside the case.
    BTW does anyone have a link to step-by-step guide to setup winxp for ssd (I mean partition alignment, pagefile disabling etc.)?
  7. #17
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Dejan
    SapproGuy
    Let us know how work...
    today has been outside -12C and CarPC has normaly turn on and boot...
    For alignment look on some OCZ thread
  8. #18
    Feb 2006
    Melbourne, Australia
    SapproGuy
    Hello Guys,
    As an avid phase-change overclocker, I can assure you that hot components will not cause condensation in cold air
    It's the other way around, when you have ice-cold, freezing components, being exposed to moist, warm air.
    Have a think about it, and don't confuse the 2. I see this misconception very often on the forums when it comes to computers.
    If you have ice-cold components in cold air, no problem - just keep warm, moist air away. Warm components in cold air, no worries.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  9. #19
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Yup, alot of misconception when it comes to cold and condensation. If you leave your carpc in the cold (like if it was installed in the trunk), then there is nothing to worry about. Cold air holds less moisture than warm, so even if the cold air inside your carpc warms up, nothing will condense because there is little moisture in the first place.
    It's only if you have your carpc installed in the interior where it may be exposed to warmer, moist air such as from a persons breathing that you should be concerned. This is apparent on a -40C day when I get in the car and my LCD screen starts getting a layer of frost on the front, even though Im not breathing directly on it.
  10. #20
    Feb 2008
    Quote Originally Posted by _Dejan_ View Post
    OK, so I finally intalled my x25-m. Today @-9C booted like a charm, enjoying the speed
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 04:39 PM
  3. Intel boards
    By carpcguy in forum Classified Archive
    Last Post: 10-14-2006, 09:17 PM
  4. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
