Results 1 to 10 of 12
Thread: Stereo only works when the car is stopped!
    Nov 2009
    Ok....I failed today.
    I installed a new sony radio into my 01 galant and it works great, as long as the car is stopped. Once the car starts moving, the radio doesn't work! It turns off and beeps 3 times.
    Any help is appreciated!
    (oh, i didn't have a wiring harness so i connected the wires using a diagram from the internet...)
    Newbie Moysie's Avatar
    Oct 2007
    Fife, Scotland
    Blog Entries
    1
    Does it go off when you remove the handbrake or do you have to start moving first before it cuts off???
    Could you maybe upload a copy of the diagram you used?
    Nov 2009
    Quote Originally Posted by Moysie View Post
    I never use the handbrake. Its like this though, I turn on the car, it works perfectly. Then i shift to D or R and start moving... thats when the radio turns off.
    Oct 2007
    Fife, Scotland
    Blog Entries
    1
    OK, could you upload the diagram you used to wire up the radio?
    Maybe you could get someone to give you a hand and do a few tests.
    Once the car starts moving test to see if you lose the voltage, or if you lose your ground connection.
    Nov 2009
    I will upload the diagram later (i will be home in few days)
    but i tried ejecting the cd from the stereo and it worked.
    Raw Wave
    Nov 2009
    Does it cut out if you just rev the engine?
    Does it cut out with headlights on/off when taking off?
    (I assume you are traveling sub sonic?)
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    And add to this list does it cut out if you roll forward in neutral...
    Jan 2008
    it is starting to sound like you are using the wrong remote wire-- some decks will allow for ejecting cd's when they are not getting any power from the remote wire, but still have constant power.
    in your car, it might have a wire to tell the radio when the car is in gear(for navigation system?)that you might be using for the turn on lead.
    Mar 2006
    Montreal
    if he's able to eject the disc in the HU's state, (when it shuts off in gear), the POWER line of the HU is functional, the ACC one is wired wrong, disconnect it and attach it to the same line as the POWER line as a test, if it remains on no matter what gear, dont connect back to that wire, instead, find the proper wire and use that...
    Feb 2012
    Quote Originally Posted by andruha1123 View Post
    Wondering how or if you resolved this, was is the wrong wire? I ask b/c I have exactly the same problem and I'm totally confused by it, I drive an 02 Galant & I also used a Sony deck got it all wired up and sat in the car all happy listening to it & then as soon as I go to move it shuts off, then comes back on at stop signs and red lights. Thanks
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  2. mp3 to car stereo cable
    By diesel_greg in forum Show off your project
    Last Post: 11-06-2009, 10:33 PM
  3. XPlod car stereo with iPod interface
    By fishheadtw in forum Newbie
    Last Post: 09-18-2008, 03:32 PM
  4. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
