Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Restart loop
  1. #11
    Maximum Bitrate DeltaFX's Avatar
    France
    Tss tss tss... okay an EP-8KTA2 is a full ATX KT133A athlon (socket A-462) motherboard....
    that probably draws cpu power from the 5V line
    And a M2 is rated for 8A Max (peak 12A < 60s) on the 5V...
    Now let's consider this
    http://mysite.verizon.net/pchardware...ec_pentium.htm
    What do we learn there : any cpu stronger than a duron (morgan) 950 will suck dry the 5V rail just for itself.
    Now Galileo is real. Muhahahahaha :p
  2. #12
    Jun 2008
    Houston
    thanks for your help, and yes i am a noob...duh thats why im asking
  3. #13
    Jun 2008
    Houston
    If it sucks dry the 5 volt rail shouldnt there be a drop in voltage? Cause there is none. Also the board is only drawing 5 amps max throughout the whole restarting cycle.
  4. #14
    Jun 2008
    Houston
    ive put a meter on all of the pins of the m2 and checked it against the original psu. everything is the same except the white wire, on the psu its giving a -5v on the m2 its giving me nothing. Ive read that after 2002 or so the use of that wire was dropped or not necessary. The mother board im using is older than that so it must need it. I supplemented power to that line, -5v while i used the m2 to power the rest of the board and it had no effect. Things are really starting to get frustrating.
  5. #15
    France
    Voltage drop, maybe not, but certainly ripples. you checked with an oscilloscope ?
    Your mobo is aging, so regulators / capacitor may be out of spec, and having hard time to smooth power grid. I don't know the TDP of your graphic card, but it needs power for sure. And kbd, mouse, tsk need 5V.
  6. #16
    Jun 2008
    Houston
    yea, I wondered about that but the only ocilliscope i have is from the 60's...was my dads. Not sure if it still works. Im at the point where I should just get another power supply. Do you think me getting a bigger power supply would suffice or do i need to scrap this board and start with something else? Money is tight so id like to just sell this m2 and spend a little more and get a more powerful one. What do you think? And what about the lack of that -5v line?
  7. #17
    France
    I said oscilloscope because a simple multimeter is not fast enough to detect pikes. Your system roughly need 5 A on the 5V rails, but could draw 10 A for a tenth of a sec, and you wouldn't see it with your multimeter.
    I don't know if the -5v line is a problem. Carefully remove the pin from the ATX male plug of your regular PSU, and try your mobo. If it still boot, the -5 line is not a problem. If not, well, you've figured it out.
    What CPU do you use ?
  8. #18
    Jun 2008
    Houston
    Thanks for the help, im at the point where i dont think its worth foolin with anymore. Im workin too hard to get this old motherboard to work when i could get a single core atom for under 100 bucks. And that works with the m2. Ive just hooked it up via inverter for now so i can use it on my road trip tomorrow. Thanks for your help though, i may try that last suggestion when i get back before I order the new board.
  9. #19
    France
    Sounds wise.
  1. Replies: 4
    Last Post: 07-27-2009, 08:57 AM
  2. Intel DG45FC Continuous POST loop???!! PLEASE HELP!
    By Archy88 in forum General Hardware Discussion
    Last Post: 05-01-2009, 08:12 AM
  3. Alternator Whine ; not related to Ground Loop
    By Trench in forum Car Audio
    Last Post: 05-01-2008, 07:13 PM
  4. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 08:58 AM
  5. Turtle Beach Santa Cruz Sound Card GIVES me a ground loop?
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-15-2003, 07:26 AM
