Results 1 to 10 of 19
Thread: Restart loop
    Jun 2008
    Houston
    Restart loop
    I dont know if this is a bios problem or a psu problem, the computer works fine when its plugged into the wall with the normal power supply. When i use the m2-atx it posts then instantly restarts, sometimes it gets bad and goes to the "start windows normally" screen, when i wait for the timer to run out and start windows normally it then restarts again. It just sits in this loop indefinitely. Ive read some other posts with similar problems but in their situations the computer randomly restarts, also in others the fan just runs. Im actually getting to post but it restarts before the windows loading screen appears.
    Is this a problem with my M2? Is my bios all goofy? Ideas?
    Jan 2008
    are you changing any hardware other than the power supply?(cd drive, memory, etc?)
    the only time i have seen that is usually with loading the incorrect drivers on the motherboard. it could also be bad memory..
    otherwise, is there any way that you could leave the m2 hooked up to power the computer while loading everything? (if you search around, there are multiple how-to's on powering the m2 outside of the car)
    Jun 2008
    Houston
    well i changed the master/save config of the hard drive last night and it booted up just fine with the regular power supply. What do you mean keep the m2 hooked up while loading everything? You mean test it with the m2 indoors on like a bench test?
    Jan 2008
    yep.
    am thinking that something about the power configuration of the m2 is built differently than the standard atx power supply, and is causing your problem, so by using the m2 to load all the software, the software will account for it.
    Jun 2008
    Houston
    ill do some digging and try to find my battery charger and hook it up to the m2-atx, but you think that will yeild different results? It will still be going through the m2 so dont you think it will have the same problem?
    Jan 2008
    (someone correct me if i am wrong, this is how i have always assumed it) usually computers start loop booting when something in the boot configuration either gets corrupted, or erased, or changed, so it might be possible that something with the m2 is changing the boot configuration just enough to the point that the computer doesn't want to start.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    this happens when a power supply is overloaded..remove some stuff and try to test boot again
    Jun 2008
    Houston
    ok I bench tested it and found out a few things, if i disconnect the hard drive from power, (the hard drive is the only other thing drawing power from the m2 besides the motherboard) the computer will boot to where it looks for the hard drive. Of course it cant find it because it is not connected. If i connect the hard drive and try to boot, the screen just goes black and doesnt even try to post. also the ammeter jumps up and down on the battery charger that im using for the bench test. So for some reason the hard drive is throwing everything out of whack. However everything works just fine when i use the powersupply that is plugged into the wall.
    Thoughts?
    I suppose the hard drive could be putting it over the edge, but this an old computer not needing much wattage but i spose it is getting overloaded.
    Jun 2008
    Houston
    the mother board is an EP-8KTA2 and i am using an old *** radeon graphics card because it doesnt have an integrated card. I suppose that the graphics card could be causing it to draw too much power, but it sure is an old weak card...like 1998 old, maybe older
    Jun 2008
    Houston
    After further playing with the situation i decided to hook up the cd drive instead of the hard drive. WHen i did this the screen just stayed black like it did with the hard drive. The cd drive should be pulling a very very tiny amount of power and still has the same effect. What im thinking is that the timing is off on the m2, it allows the computer to boot fine but when i attach something to those other rails it flips out and gets confused.
    Anyone have any ideas what is going on or how to fix it?
  1. Replies: 4
    Last Post: 07-27-2009, 08:57 AM
  2. Intel DG45FC Continuous POST loop???!! PLEASE HELP!
    By Archy88 in forum General Hardware Discussion
    Last Post: 05-01-2009, 08:12 AM
  3. Alternator Whine ; not related to Ground Loop
    By Trench in forum Car Audio
    Last Post: 05-01-2008, 07:13 PM
  4. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 08:58 AM
  5. Turtle Beach Santa Cruz Sound Card GIVES me a ground loop?
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-15-2003, 07:26 AM
