Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: New Jetway Mini ITX Board no display *HELP*
  1. #31
    Mar 2006
    Colorado, but Canadian!
    Perhaps
    1.9in x 2.9in -- 47mm x 73mm
  2. #32
    Dec 2009
    2k1Toaster You are the man! i got the ddr2 ram at 533,mhz and lo and behold.... IT WORKS!! Thanks bro! And thanks to everyone with suggestions. Now i can finish my project!
  3. #33
    Dec 2007
    good to hear that you are up and running
  4. #34
    Mar 2006
    Quote Originally Posted by them0dster View Post
    Glad I am not the only one to be frustrated by a Jetway board. Although once they are running, they are quite nice overall. Only other issues I have had with them were video resolution related, but hopefully those have been since fixed...
  5. #35
    Dec 2009
    one last question about my pain in the azz jetway... it has a S-Video port and Yellow video port.. Neither of which can work which sux big time.. I planned on having this machine plugged into my TV.. Now i cant. If my tv had a vga port i would be fine as that port is the only one that works properly. Have you guys had any luck with the s-video?
  6. #36
    Mar 2006
    You have to either:
    (a) enable output via Windows using Jetway's software
    or
    (b) enable it as the default video device in the BIOS
  7. #37
    Dec 2009
    hmmm... ill def. look into that. The S-video would work for a few but then get fuzzy. When i try to use the yellow jack, i get nothing at all. Did u have this problem? What jetway software by the way? i installed the drivers.. So im guessing there is software somwhere installed due to that process.
  8. #38
    Mar 2006
    Are you wanting to use the video out for your main screen? That would be a bad idea to cheap out there, and I suggest using a VGA monitor. That and it will be better.
    I had originally intended for my jetway board to be used in a HTPC setup, but it wouldn't continuously output from the svideo jack. It was the for the best anyways because I got a better suited motherboard with HDMI out and it has been a great thing!
    When I tried to use it in the car, I had a VGA screen. So many other problems with it though just frustrted me and I gave up after a couple months.
  9. #39
    Dec 2009
    so yea the s-vid garbage port doesnt work at all.. now my issue is trying to get the yellow video out to work.. i found nothing in bios and i cant find jetway software that would enable it. I have a monitor to use but i prefer my bigger TV so i dont have to a)burn movies anymore and b) use a flash drive on my dvd player anymore.
  1. Lilliput screen on Ubuntu
    By yam125 in forum Linux
    Last Post: 06-13-2011, 11:19 AM
  2. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 07:06 PM
  3. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  4. Xenarc with Mini Itx and Powerstrip
    By Glyn in forum LCD/Display
    Last Post: 09-24-2002, 10:26 AM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
