Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: New Jetway Mini ITX Board no display *HELP*
    Dec 2009
    Hey i have a mini itx board from jetway. And the problem is that i have it hooked up and for some reason i cant get a display. I tried the S video and the yellow video port. i get nothing. i also tried to use the vga port... no display. This motherboard is brand new and i cant find the manual.. Anyone have any suggestions?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'd suggest you start by posting more information. Does it beep? What's the model? How much ram? Make/model/speed of ram? What power supply are you using? Do you have the P4 connector hooked up if it has one?
    Tidder
    Try RevFE
    Dec 2009
    jetway jnc93-330w-lf
    http://www.newegg.com/Product/Produc...82E16813153135
    1 gb of ram i think 133 mhz or 333
    Using a picopsu (dont know the power, i bought it off somebody)
    The processor fan goes on, as does the motherboard light. And the system stays on.
    No beep though.
    Just cant get a display no matter what i do
    Low Bitrate majasticmoose's Avatar
    Dec 2009
    is the computer turning on (hard/cd drives spinning)?
    Dec 2009
    i didnt hear or feel the HDD spinning. Fans are spinning though
    Jan 2008
    if your using 133/333mhz your using the wrong memory-- according to the specs, you need to use ddr2 533 mhz
    another way to check that the computer is booting up properly is to turn the num lock light on and off manually-- if the computer posts, you will be able to control the numlock light, if it isn't posting, the numlock will not be able to be manually turned on and off.
    Dec 2009
    im using HP/Compaq 1 GB PC2 5300 667 MHZ CL5 ECC Registered DDR2 SDRAM DIMM
    Dec 2009
    yup that's the problem, wrong RAM installed. You need DDR2 at 533 MHz like soundman said. It's also called PC2-4200 RAM.
    Dec 2009
    Really? The higher Mhz causes that kind of problem? Would that actually prevent me from recieving no display when i power on?
    Dec 2009
    Actually on further research I don't think it should affect the motherboard.
  1. Lilliput screen on Ubuntu
    By yam125 in forum Linux
    Last Post: 06-13-2011, 10:19 AM
  2. Intel Itx board into C134
    By Craggy in forum General Hardware Discussion
    Last Post: 10-09-2006, 06:06 PM
  3. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 08:46 PM
  4. Xenarc with Mini Itx and Powerstrip
    By Glyn in forum LCD/Display
    Last Post: 09-24-2002, 09:26 AM
  5. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 03:20 PM
