Results 1 to 7 of 7
Thread: Where can I buy a front panel switch for motherboard?
    Dec 2009
    Bozeman, MT
    I'm looking for the power button module that hooks into a motherboard. I have been searching for a while and the thing is apparently called the front panel switch.
    Does anyone know where I can get one of these that works in my motherboard (645 ultra)?
    Attached is an image of the part of the guide that came with my mobo explaining the front panel connector.
    Dec 2006
    You can solder any momentary switch to those 2 leads in the header, or you can buy something like this on ebay.
    Portecho: Entertainment Technology News, Reviews and How-to's
    Elsewhere
    Scavenge a power switch from an unused computer case.
    Cost = FREE
    How about the Wiki?
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    You can also use something metal to just jump the two pins momentarily, screwdriver, paperclip, etc. This probably isn't the safest solution but it works if you are careful and know what you are doing, make sure you get the right pins. I do this when I'm working on the carpc on the bench
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    You can use a normal off, momentary on toggle or push button and wire that to the headers on your motherboard. I've used both in the past when I used an inverter instead of using an intelligent DC/DC power supply.
    I have bad luck with vehicles...
    Dec 2008
    Quote Originally Posted by Ramb0_Command0 View Post
    what about making a coin drop that uses the quarter to contact the two pins... 25 cents for a bootup
    Dec 2009
    Bozeman, MT
    Thanks for the tips everyone
  1. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:51 AM
  2. Where to Buy Touch Screen Panel only
    By badandy4you in forum LCD/Display
    Last Post: 06-02-2004, 11:35 AM
  3. using cat5 to wire front panel
    By Crast in forum General Hardware Discussion
    Last Post: 12-04-2001, 01:30 PM
