Results 1 to 2 of 2
Thread: Hibernate Trigger Problems
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Question Hibernate Trigger Problems
    Hi,
    I was currently having issues with my usb devices not working after resuming from hibernation. So, i created an autoit script which i converted to .exe which enables and disables the usb devices when going into hibernation and resuming from hibernation which is using devcon commands. The program i use to call the .exe is hibernate trigger.
    The problem is when my computer hibernates, my usb devices get disabled, but when i resume from hibernate hibernate trigger doesn't run the resume command, so my usb devices stay disabled.
    I have tried manually clicking the disable.exe and enable.exe which i created and works fine, just doesn't work through hibernate trigger.
    I also put hibernate trigger in my startup folder, but do the applications in the startup folder get called when you resume from hibernation?
    ps. Here are the main commands i have in the 2 .exe i created.
    enable.exe:
    c:\devcon enable @usb\*
    disable.exe:
    c:\devcon disable @usb\*
    I also did the same thing, but put the "pid_****" same effect.
    Any suggestions.
    Mar 2007
    Milwaukee, WI
    Quote Originally Posted by TeamRSX View Post
    Items in the Startup folder are only run when first logging into windows. They do not run on resume from hibernate/sleep.
    Not sure if it matters, but the devcon examples don't use the @ symbol before USB.
    Other than that, sounds like a problem with the hibernate trigger software. Try getting a hold of whoever developed it.
    Brian
    2008 Grand Prix GXP
    [=====-------] 50% - Main Hardware Complete
  1. Variables to trigger outputs
    By jimp in forum Fusion Brain
    Last Post: 04-27-2008, 01:27 PM
  2. tiny xp and experience server2k3 problems
    By o45739 in forum Operating System Optimization
    Last Post: 02-17-2007, 09:11 PM
  3. resume from hibernate gx260
    By TSXPC in forum Centrafuse
    Last Post: 02-01-2007, 04:38 PM
  4. RR Problems with hibernate (No Sound)
    By dudeness in forum Road Runner
    Last Post: 12-19-2006, 02:03 PM
  5. Motherboard MB896 Hibernate problems
    By mbkowns in forum General Hardware Discussion
    Last Post: 05-29-2006, 02:24 AM
