Results 1 to 5 of 5
Thread: stand by/ hibernating issue
    Nov 2009
    I have my computer setup to go into stand by when i turn off the car but i can not get it to hibernate after a given time frame. What am I doing wrong?
    Jan 2008
    what os are you using? if xp, i do not believe that there is a way to do that (though i could be wrong) if win 7, i believe that it needs to be setup as hybrid sleep to allow it...
    if you could list your os, and motherboard model, it might help someone answer your question a little better(some motherboards support different features).
    Nov 2009
    I am using windows XP, and my board is a Commell LV-666 board :Embedded VIA C3/Eden 1.2 GHz
    Nov 2006
    What you are attempting to use is something called "hybrid sleep" where it sleeps for a certain time period and then wakes back up when that time expires and goes into hibernation. This is only available on Vista (Service pack needed) and windows 7.
    Nov 2009
    ok, what would be my best option to save my battery since I am using xp? Should I just have it to hibernate on power off? Oh, I am using a m2 power supply. I am using jumper 1 setting. If I set it to stand by, will the m2 shut off power completely after a given time to save my battery?
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 04:48 PM
  2. HP Laptop LCD Exstension issue
    By kendallb in forum LCD/Display
    Last Post: 03-22-2009, 06:16 PM
  3. My RR/DFX 4.0 100% CPU usage issue
    By Minoritydan in forum RR Bug Tracker
    Last Post: 12-23-2008, 12:40 PM
  4. No audio after resume from hibernate issue - almost fixed - Help me finish?
    By Trin in forum Software & Software Development
    Last Post: 07-26-2008, 07:35 AM
  5. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 10:00 PM
