Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: New ASUS and Zotac Mini-ITX boards
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    Soo, new kids on the block from asus & zotac on the Mini-ITX scene:
    Asus AT5NM10-I
    -Intel Pine Trail-D
    -Atom D510
    -Intel GMA 3150
    -5.1 HD audio (NM10 Express)
    -2x DDR2 DIMM
    -2x SATA-300
    -1x PCI
    -passive cooling
    AT3IONT-I and AT3IONT-I Deluxe
    Facelift on AT3N7A-I, with PCI Express x16 (!!!) and passive cooling
    Deluxe comes with remote and a 90W power supply adapter
    Zotac H55-ITX WiFi
    A beefier solution from zotac:
    -LGA1156 slot
    -H55 bridge
    -PCI Express x16
    -2x DDR3
    -6x SATA-300
    -eSATA, SPDIF, HDMI, DVI on backpanel
    -802.11b/g/n WiFi
    (images and info are from ComputerBase, Overclockers Club, and from Prohardver)
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Oh man... I want to sell my old ION and get that asus now. The Pine-Trail Atom is going to run a lot more efficiently.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by kev000 View Post
    First it's cool, but suddenly: "OMFG! LPT connector in 2010!!!"
    Even ASUS does strange (stupid) things:
    As I said in my worklog, I have 30 nettops with AT3N7A-I.
    Problem: VGA connector is above the SPDIF.
    So when you plug it hard (or if you push the pc to the wall accidentally)
    you can brake off the connector and ruin the mobo!
    I can tell you, that the Zotac board will have the same problem with the DVI connector
    Check my worklog:
    Constant Bitrate vull's Avatar
    Oct 2007
    are these better than this?
    Asus AT3N7A-I - Atom 330 + nVidia Ion
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by vull View Post
    If you don't depend on PCI or especially if you want to go with a PCIe
    device (asus xonar hdav 1.3 for example), they are better.
    Well, the AT3IONT-I is a facelift on the Asus AT3N7A-I you linked,
    with PCIe instead of PCI, passive cooling instead of active, etc.
    Best for HTPC or for carPC with heavy multimedia.
    Asus AT5NM10-I is almost the same, but it has the new Intel Pine Trail-D
    technology, lower power consumption, at the cost of inferior multimedia
    (no fancy geforce, HDMI, 7.1). Best for general carPC use, you can add
    a sound card or a video card later, as it has PCIe too.
    Zotac H55-ITX WiFi is a bit different, it doesn't have an integrated Intel Atom
    onboard, but you can add an Intel i5 or i7 to it. It's useful, if you want to
    make small pc for gaming, or a beefy HTPC, go with this. A bit power hungry
    for a carPC, but if you've got a V8, it does not matter
    Check my worklog:
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    asus xonar hdav 1.3
    Does this work with Linux? I didn't see it on the alsa-matrix page, but i may have overlooked it.
    Oct 2009
    Budapest, Hungary
    I think it works with C-Media 8788 driver. See this link.
    Check my worklog:
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    i can't find a lot of info on pinetrail, is it released yet? what's the advantages over the original atom?
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by Belo View Post
    I picked up a pinetrail based netbook at bestbuy (atom 450). The advantages are it has the gpu built into the cpu and a much more effecient chipset. That means it draws less power. Also having the gpu in the cpu reduces latency and improves bandwidth resulting in increased performance. As for a pinetrail based ION, i don't think they are released yet.
    Jan 2010
    Buffalo, NY
    Are these not out yet? I can't find either for sale
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
