Results 1 to 10 of 13
Thread: IC Question
    Oct 2006
    IC Question
    I'm looking to simulate for 0 - 20 ma signal for making a simple I/O board to test some programs.
    My analog card has a 50ohm input resistance so i need to regulate the current going into the analog card. This is pretty easy if it was just one input i need to simulate. Just use a 1.5v battery with some resistor. However i need to simulate 4 input so a resistor network wouldn't work because if i change one current i'll affect the other 3. So IC guru could you please point me to the right chip that will enable me to regulate and adjust 4 independent current loop using 24V input. I would like some sort of current limiting feature so i won't go over 20 ma. Also would like to adjust using some sort of resistor pot that will give reasonable accurately between 0 and 20mA at 1 or 2 mA increments.
    Any help is greatly appreciated
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I think you're best bet is just resistors and switches if it's just for temporary use. Unless you want to spend some money on a high end power supply or build one.
    Oct 2006
    if you mean the 24 input voltage regulator as the power supply, i already have that, a very good one as well.
    Mar 2004
    Florence Yall, BFKY
    Well, here's an example of a variable limiter and some explanation.
    http://www.radio-electronics.com/inf...nt_limiter.php
    Oct 2006
    will look into this! thanks for the info!
    Oct 2006
    looked awfully like the current mirror circuit, that i learned a while back in school.
    time to crack out the textbook.
    i was hoping it would be in a simple IC package like the lm377, except i don't think the lm377 does exactly what i want.
    Mar 2004
    Florence Yall, BFKY
    I think that feedback method will be the simplest. Check out the LM2673. It has adjustable current limit, but it's an entire switching supply. That's probably the only type of chip solution you'll find.
    Oct 2006
    LM2673 wouldn't work since the current limit range is not even near the mA area.
    Oct 2006
    so nevermind, i found 0 - 20 ma optical rotary encoder that'll do what i want.
    it'll be easier than trying to pick up circuit stuff again.
    thanks for the help curiosty!
    Mar 2004
    Florence Yall, BFKY
    Sorry, I should have looked at the datasheet. Nice find on the rotary encoder. That could make for an interesting input device as well.
    I also found the L200C, which might have worked for V and A control.
    http://www.zen22142.zen.co.uk/Circuits/Power/l200.html
    Although the example is 100mA min, the datasheet shows much lower.
  1. heavy-duty OBD standards support question
    By Michael2006 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-07-2007, 05:13 AM
  2. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
