Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 83
Thread: BoomzBox HD Radio. Not quite a review, more of a progress report.
  1. #11
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by justchat_1 View Post
    How does the com protocol for the boomzbox compare to the directedhd or visteon hd units?
    Same style communication, but different protocol. It still uses binary communications rather than ascii for the most part (besides the text of course), but there is a message format just like the directed/visteon units so you can set up enums for the commands to make things readable. The base message format is:
    0x5A 0xA5 XX XX YY ZZ ZZ ZZ ZZ ZZ QQ
    0x5A 0xA5 is a header that is in all messages
    XX XX is the length of the message ( the y's and z's only)
    YY is the message identifier, which defines what the message is all about
    ZZ is the actual message
    QQ is a checksum
    Example:
    0x5A 0xA5 0x00 0x04 0x05 0x01 0x03 0xD3 0xEF
    This message has 4 bytes, 0x05 0x01 0x03 0xD3.
    0x05 means "Tune to station",
    0x01 is FM (0x00 is AM)
    0x03 0xD3 is 979, which is 97.9
    0xEF is the checksum (I made the number up, since I don't have an easy checksum calc in front of me)
    That's off the top of my head, so it could be wrong, but you get the idea. I'll be releasing a detailed protocol specification as soon as I figure more stuff out, and neaten it up
    RevFE
    My Shop
  2. #12
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    gotcha....I was just wondering if it was close enough that I could tweak it and use my directed unit to test. Looks like more effort then its worth though.
  3. #13
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    You only have to modprobe vender=0x0403 product=foo in the 2.6.28 kernel that comes with 9.04. In 9.10+ it'll just show up as a normal ttyUSBx device. Also, 9.10 and ftdi is broke. I hear they've got a fix in the "proposed" updates, but my testing has yet to prove that it works.
    As for mac users, i have no idea how they are going make it work.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I had trouble getting the BoomzBox HD to work on my Intel Mac even using a Windows install on it. It appears to install but then it doesn't work. :-(
    It won't work on OS X because of the FTDI driver issue.
    Want to:
  5. #15
    Jun 2004
    Westminster, MD
    Alright, modprobe worked thanks Kev. That could be a potential solution for Linux users, but is still not optimum. Bugbyte: I know that there is an application FTDI has that allows you to change the vendor/product ID's... so if all else fails you could get on a windows machine, use their app and change the ID's back to the proper values which would allow it to work in OSX no problems. I'm not sure how viable of a solution this is. I know Mitch has the ability to distribute an application which updates the VID/PID(He did it once to fix an mis-labeling), but I can almost guaranty he won't release a version that switches them back to the default values... but I'll ask him later anyway :/ This leaves us with each individual manually changing theirs using the FTDI Windows application as the only option for OSX users.
    RevFE
    My Shop
  6. #16
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by Bugbyte View Post
    AFAIK, something like obdftditpty will work for it on OSX. Gary will have to confirm though.
  7. #17
    Jun 2004
    Westminster, MD
    I'll get together with him and play around, see what I can find, though I couldn't get the method that obdftdipty uses to work with the boomzbox.
    RevFE
    My Shop
  8. #18
    MySQL Error
    Oct 2004
    using the default PID would be a voilation of terms with FTDI, that is for their products (usb to rs232 dongles) this is not that, this is specifically made for a specific piece of hardware
    luckly in this case its just a comport, and linux fully supports custom PIDS
    u just need to edit a file (i dont know which, but its known for LINUX users)
    solve the problem with LINUX config
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #19
    MySQL Error
    Oct 2004
    also... there is some info here
    http://www.ftdichip.com/Documents/Te...FT_000081).pdf
    i dont know enough about linux to tell you exactly what to do
    but this looks like it should help
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #20
    Jun 2004
    Westminster, MD
    Quote Originally Posted by mitchjs View Post
    Huh... then I guess the GPS modules, obd2 devices, Serial hubs, Arduinos... (shall I go on) Are all in violation of the terms... I wonder how they do it... but somehow they do, and they maintain compatibility with Linux and OSX without any special tricks. All the FTDI chip is doing in your device is a usb to ttl serial converter, it's nothing special unless I'm missing something... since all the default drivers for both Linux and Windows work great.
    Though thanks to trip, the Linux side seems to be up and running, OSX is just going to be an issue.
    Edit: Don't get me wrong, I'm not dissing the product, it's a very nice product and I plan on putting it in my car once I get my carpc back up. I'm disagreeing with your method of implementing the FTDI setup, as it has caused me issues with integrating in other operating systems. I am well aware that you have no plans to support other operating systems, and that is your prerogative... but expect flak when you exert extra effort that happens to make things difficult .
    RevFE
    My Shop
  1. HDZ300 Zoom HD Radio + Mitch's HD Cable
    By Iceplayagt14 in forum Classifieds
    Last Post: 11-08-2008, 08:12 AM
  2. HD Radio + Latest Road Runner not working for me
    By BlackStealth in forum Road Runner
    Last Post: 09-28-2008, 02:00 PM
  3. HD Radio
    By pcullin in forum Car Audio
    Last Post: 09-01-2008, 12:31 PM
  4. Which EQ for HD radio?
    By ccrum in forum RR Skins
    Last Post: 06-24-2008, 11:26 AM
  5. Phx Area HD Radio Question
    By 99WhiteSleeper in forum Car Audio
    Last Post: 06-23-2008, 12:27 PM
