Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: ByByte Black Box N Nano-ITX Car PC Case
  1. #11
    Jan 2006
    But the fader control will be on the amplifier, not the PC?
  2. #12
    Newbie Pegasus50's Avatar
    Apr 2010
    Thanks for updating this thread guys. I'm hoping to integrate into a system which has balanced outputs so I'm really focused on amps and wiring issues right now. Also planning on using the Via pico-itx board and the BBN. I really like to see how you mounted your board as a kind of reference for my own build.
  3. #13
    Jan 2006
    Sure. I'll take some pics when I get behind my dash next time. I'm planning to upgrade my hardware so while dismantling the PC, I can show you how it looks with the motherboard only.
    For now, all I can say is I laid the board on the bottom of the case and marked out where the mounted holes would be. I marked the four corner holes of the motherboard. I then removed the motherboard and drilled the holes in the case. I pushed my risers into the holes and glued them using some two-part epoxy. The risers are about 6mm thick are essentially thick washers and each riser has a threaded hole down the middle - I made sure I had screws to match the threads perfectly. I laid a sheet of anti-static film on the bottom of the case to prevent the underside of the motherboard from making contact with the case. Finally, I placed the motherboard on the risers and inserted the four screws.
    Hope that's detailed enough to give you a mental picture of how to do it
  4. #14
    Jan 2008
    Quote Originally Posted by MeeM View Post
    correct, but it is another option...
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
