Results 1 to 6 of 6
Thread: Is an 8 port USB hub too much?
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    Hello Everyone,
    I'm currently using a Rosewill 8 port USB hub which I have powered through a 5v inverter in my car.
    It wasn't until recently that I began to think that perhaps I have too much going through this hub at once, and that could be causing problem for my system.
    I have:
    - GPS dongle
    -External 500g Hard Drive w/ music and movies
    - bluetooth dongle (though it's not being used at the moment)
    - touch screen interface for my motorized in dash screen (which has been acting on and off lately)
    -External wireless keyboard/mouse
    -USB soundcard
    All plugged into my hub at once, and only 1 USB B wire being run out to my PC. Am I using too many items at once to only have 1 USB B wire being run into my PC? Should I try plugging my hard drive and GPS into my laptop directly to preserve bandwidth?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    If it works fine without too much lag, being slow for your liking, or errors then I wouldn't worry about it.
    Dec 2008
    i dont think gps uses much bandwidth, but i would for sure put the harddrive on its own port.
    Jun 2009
    In my last setup I used two 7 port USB hubs, one powered, one not, never had any trouble with all slots full. I had much more plugged up to mine than you have too.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Power:
    A regular laptop hard drive is going to use about 1/2 of your available power. An SSD will use about 1/3.
    GPS, Sound Card, bluetooth and touch screen will use about 1/10 of available power combined. So yea your fine in the power department (I know that wasn't the question).
    Bandwidth:
    Bandwidth usage is also fine. Hard Drive (unless your talkin $500+) will use 80% of available bandwidth max (more likely 20%). Audio another 2% and all the rest <1%.
    Nov 2007
    Long Island, NY
    Ok so I should be fine with my setup the way it is now. I'll stick with it then. Thanks guys.
  1. USB hub problem always disconnecting / connecting
    By fire in forum General Hardware Discussion
    Last Post: 09-25-2009, 03:30 PM
  2. disable power to a usb hub?
    By dragons0088 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-05-2009, 07:00 PM
  3. D945GCLF2 + USB Hub
    By Urbanmindz in forum General Hardware Discussion
    Last Post: 05-20-2009, 10:37 AM
  4. Replies: 5
    Last Post: 10-02-2006, 01:40 AM
  5. 4 port usb hub for $4.99 shipped
    By evilkokonut in forum General Hardware Discussion
    Last Post: 09-11-2006, 09:41 AM
