Results 1 to 6 of 6
Thread: D945gclf2d psu?
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    D945gclf2d psu?
    I just purchased a D945GCLF2D to replace my fried MB. I'm curious if my DSATX 220W power supply will work with it?? The MB has a 2x12 connector and the PSU only has a 2x10. Will that work or will I need an adapter? Also, is this PSU powerful enough. This is what it's listed at, if it helps: 12V@12A, 5V@12A, 3.3V@10A, [email protected], and [email protected]
    Thanks.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Jul 2008
    That should be more than good enough, the board draws very little 12v (around 400ma max, IIRC). Most of it's draw is 5v, and even then it's only around 4 amps.
    Mar 2006
    Pennsylvania
    Ok, thanks. I thought so, just wanted to make sure. But, is it ok to use a 20 pin cable on the 24 pin plug? I've used 24 pin cables on 20 pin plugs with no issues.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Jul 2008
    It may be okay. The extra pins are just for extra 12v current, which is not needed for this board, but the board may require them to be connected anyway. Likewise, the P4 connector is just to provide extra power, and the ATX connector could easily supply the <0.5A that this board requires, but the board will not boot without the P4 connected.
    I used an M3-ATX with this board and it seems to work fine so far (20 Pin connector)
    Mar 2006
    Pennsylvania
    Cool. Thanks.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Mar 2006
    Pennsylvania
    Seems ok. Now if I can figure out the small bugs again....like why Xport has issues with my GPS and HD radio now.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 06:55 PM
  2. Remove Case DC-DC PSU?
    By Uther in forum Power Supplies
    Last Post: 08-27-2006, 10:33 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 11:04 AM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 12:08 AM
