I had one, but, got rid of it for the color model. Anyway, you can order a spool of the 16 wire ribbon (or ribbon wire whatever you want to call it), from many computer/ electronic stores (or u may even be able to place an order at your local radio shack (check the catalog)). The B/W LCD only uses 15 of the 16 wires, so you could just remove the last one seeing as you won't need it.Originally posted by subarump3:
Does anyone know where you can get a longer version of the 2 cables these screens use? Thanks!
The 2 wires for the inverter can just be extended by adding some wire(18 guage should suffice) into the original line (it is only 2 wires so it will take no time at all).
LinkBack URL
About LinkBacks
