Results 1 to 4 of 4
Thread: Power requirements for slim slot DVD from store
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Hi All,
    I received the drive yesterday, and it comes with a power cable that terminates in a USB connection instead of a standard power connector.
    My question: this drive pulls 2A @ 5v. A USB hub provides 500mA at each port. Hooking this drive up via its supplied cables (one standard USB connection, and the power cable that terminates in USB connection also) would provide 1A @ 5v. So - seems like I'm 1A short.
    What are people doing here (and why was it designed this way)? I suppose I could cut the USB connector off and wire it direct to a 5v source, or - would getting a 1:2 USB power cord 'splitter' for both connections solve my issue (while taking up 4 USB ports)?
    Thoughts?
    TIA,
    Per
    Jan 2008
    i would wire it to the 5v line on the power supply.
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    I opened the USB cable and connected 5V from external source. This is the expensive way if you do not want to use 5V from the PC supply. (which I did not)
    I am not sure these splitters are according to USB spec anyway as getting 500mA instead of 100mA is a negotiation with the hub in itself. Do the power splitters have two USB "devices" that does that?
    I think they are only cable. Could be wrong. Anyway, getting power from 4 USB ports is not...beautiful.
    Jan 2004
    Seattle, WA
    yeah, agreed. i'll cut and power via 5v POL. thanks everyone!
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 04:56 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
