Results 1 to 4 of 4
Thread: DIY shielding for power cable
    Jan 2010
    Ohio
    So i'm routing all my wires and mounting the carPC in the trunk. My problem is that I relocated my battery to the trunk, the carputer is going on the opposite side but I have 1/0 welding cable running to the engine compartment that is pretty close to the carPC. I'm pretty sure that the welding cable has no shielding wrapped around it, is there a way I can make shielding around a couple foot section, or is there something like a loom that I can purchase to shield it? Thanks for the help!
    Raw Wave
    Nov 2009
    Why do you think you need shielding?
    (A small bypass cap should remove any hi-freq noise of that's a problem...)
    Jan 2010
    Ohio
    Well while the interior is all out I just wanted to cover all bases. I just don't want any interference in my audio system from the power cable being pretty close. And what exactly is a bypass cap (I would assume capacitor?) What does it do and where does it go?
    Raw Wave
    Nov 2009
    Others may be better to advise on the reality of shielding requirements - I just find it strange that a core power distribution cable would need it....
    The bypass cap I'm thinking of is something like a 0.1 or 0.01 etc ceramic capacitor - typically the size of a finger nail.
    They are placed at intervals or terminations of any power (or input!) cabling - eg, from +12V to ground at noise-prone amps and loads, or across inputs etc (ie, from the signal-active to its ground or shield).
    The capacitors merely short out AC signals - the smaller the cap value, the higher the frequency (meaning they act like a high-pass filter; they will not short/conduct DC or low frequency noise/signals).
    If EMI is the problem, they can prevent the original hi-freq source, or filter off the hi-freq induced noise.
  1. Hardware Review: Custom LVDS LCD Cable by MotorCity
    By Giuliano in forum The Review Palace
    Last Post: 11-04-2010, 06:51 PM
  2. Alpine IDA-X001 and High speed cable woes
    By Lurkerlou in forum Car Audio
    Last Post: 08-13-2007, 08:59 PM
  3. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 04:45 PM
  4. vga cable for lilliput
    By JaxPt in forum LCD/Display
    Last Post: 02-24-2005, 11:52 PM
  5. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
