Results 1 to 8 of 8
Thread: sata to ide ???
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    sata to ide ???
    it would be nice to add two more sata ports to the D945GCLF2 and use the ide port.
    heres the issue, ive tried two different adapters that just hang out in the ide port on the mobo and use the floppy connector for power but they dont work and cause the board the boot slower than cold syrup.
    they were the cheaper ones, but before i waste more beer money on useless plastic, i was wondering if any one has any of these sata ide adapters that really work and what they do to boot times.
    thankx
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    I've seen sata -> pata converters but I've never seen pata -> sata. It won't improve speed at all even if there were adapaters. pata is 133MB/s which is much faster than any reasonably priced magnetic drive can reach. So unless you are using SSDs, you aren't going to see a difference if by some low chance you do find a pata -> sata adapter.
    If you want a few more sata ports, you should have gotten an ION board .
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Feb 2010
    if i could have found an ion for 45$ with ram i would have jumped on it
    anywho i found a few from startech.com <$20
    i looked at ssd drives but not for a carpc tooooo much $$$
    but anything has to be better than the sata > usb im using now
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    wait, so you have a pata drive you want to use on sata? Sure, those adapters should work. It's the other way around that I had no idea if such a thing existed.
    From the benchmarks I've seen, those adapters actually slow down data transfer a bit. You're biggest bottleneck is going to be the actual drive. If you have a slow drive, no connection (usb included) is going to help much.
    May 2008
    No, I think he has SATA drives and it trying to use a SATA->PATA adapter in reverse.
    What I think he is actually looking for is something like these:
    http://www.cooldrives.com/satoidecofor.html
    (first result from a google search).
    Feb 2010
    nope i have no pata drive, all sata
    but some of these are advertised as "bi-directional" so would it make sense that you could convert a pata drive to sata OR a sata drive to ide/pata ?
    seems like if these work they would be a great alternative for people looking to add a hdd (or dvd drive) without taking up usb real-estate.
    Raw Wave
    Nov 2009
    Not quite the same thing, but I use $25 USB to SATA & PATA (2.5" & 3.5") (includes 2A PSU) and that allows direct PATA-SATA transfers.
    But that is NOT from STAT or PATA ports (just the HDDs).
    FYI - if you get them, ensure the SATA uses a lead to connect - I found the SATA's that plug direct into the "dongle" to be unreliable.
    Feb 2010
    *update*
    i broke down n ordered the top adapter and still no luck
    i did some diggin and found that the BOXD945GCLF2 just cant do some sata pata combos
    seriously thinkin of swapin boards ...
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Connect IDE Power Supply to SATA HDD?
    By shaner3721 in forum General Hardware Discussion
    Last Post: 02-15-2010, 11:36 PM
  3. SATA to IDE adapters. Experiences? Are they slow?
    By nobb in forum General Hardware Discussion
    Last Post: 11-30-2008, 12:52 PM
  4. CF to SATA or IDE
    By ambush276 in forum WinNT Based
    Last Post: 07-20-2007, 05:13 PM
  5. convert ide to sata. Will it work for cd/dvd's?
    By churnopol in forum General Hardware Discussion
    Last Post: 08-12-2005, 04:53 PM
