Results 1 to 2 of 2
Thread: Best Grounding option
    Nov 2008
    What is the best way to ground my screen, pre amp, sub amp and computer.
    I found the main point in my car where everything this grounded. Should i run a ground wire from each of my items to this main ground point... etc. screen computer.
    Or should i use a common ground. 1 ground wire and just tap into that ground from each of my items.
    Feb 2010
    A car is a pretty noisy environment. Therefore, your grounding strategy may depend on how you handle the grounds and power in each of your equipment. i.e. how well they are filtered from the rest of the car's electrical noise.
    Ideally, you don't want ground return currents from other devices in the car taking a route through your equipment. Therefore, a single point of ground return from all your equipment would be best. Make it a large return path (relative to your equipment needs) for a good return path for the current. Then connect all your equipment to that one ground path. Also, be sure your equipment does not accidentally touch the car chassis and provide another return path inadvertently.
  1. Best Video Option??
    By eribs4e in forum General Hardware Discussion
    Last Post: 04-02-2008, 01:28 PM
  2. Internet radio option disappeared
    By clubtech in forum StreetDeck
    Last Post: 02-17-2008, 12:28 PM
  3. Back-up Camera Option on 2005 Pacifica
    By mthomas58 in forum LCD/Display
    Last Post: 01-26-2008, 06:42 PM
  4. Lilliput woes
    By timekiller in forum Linux
    Last Post: 06-19-2007, 11:22 PM
  5. EXE option in launch menu?
    By cyberlancer in forum Road Runner
    Last Post: 02-17-2005, 11:30 AM
