Results 1 to 3 of 3
Thread: BMW stock amp Draws too much power??
    Nov 2008
    so a little background.
    Car
    BMW 330ci
    Power supply
    m2 atx
    mother board
    D945GCLF2
    Here is my issue.
    For some reason when i connect my factory remote wire to the J6 pin it drops down the voltage from 13.6v to 8.1v.
    8.1 volts is not enough to turn on the factory amp. i checked the output of the j6 remote wire and it is a constant 13.6v when connected to nothing and the car is on. But like i said as soon as i connect the j6 to the remote wire for the factory amp it drops down to 8v.
    What could be the reason for such a heavy load to drop down the output by almost half??
    any help would be great.
    Jan 2008
    i have read that it is a common problem with the m2(i use a dsatx, and a cars switched power line.)
    according to this thread:
    http://www.mp3car.com/vbulletin/car-...-amp-turn.html
    you should try to power the amp from a switched line in the car..
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The M2 has a wimpy output. Try a transistor to help it out.
    http://www.mp3car.com/vbulletin/powe...-up-relay.html
  1. tapping into stock amp
    By roflcopter in forum Car Audio
    Last Post: 08-11-2009, 09:49 AM
  2. Replies: 27
    Last Post: 07-21-2009, 09:27 PM
  3. Power for JL A6450/PC/future amp
    Last Post: 05-20-2008, 03:52 PM
  4. 10 amp power inverter that is 170 watts constant
    By black06stang in forum Power Supplies
    Last Post: 06-06-2006, 10:41 AM
  5. Too much amp power for stock speakers?
    By black06stang in forum Car Audio
    Last Post: 04-30-2006, 09:02 AM
