Results 1 to 10 of 15
Thread: Board Best suitable for carpc needs
    Mar 2010
    Miami
    I am impressed with many of the Zotac boards. But they have a 1.6ghz atom CPU. I was wondering if this is usually enough for most carpc uses. I was also looking at an Intel BOXDH57JG motherboard with a Core i5 3.33GHz processor. I like the idea of this combination because I feel like it will continue to support my needs for other computing. Also, which would probably have a quicker boot time?
    Jan 2008
    the atom is usually enough for a typical carpc-- ie: usually running music, gps, bluetooth and web.
    i run heavy audio processing in my own car, and so i updated to a dual core pentium, but still use the atom based mobo at home as a family computer-- with little noticable difference between that and a normal computer
    boot time varies widely with usb devices, bios options, and in some cases, the actual bios(this would be in the case of the intel 945glc board with a creative x-fi sound card-- the 2 will increase post time to +15-30 sec, with no other devices...)
    Mar 2010
    Miami
    should i make the decision for my board based on the CPU or the features included on the board that would best suit my needs?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Both, but I would say that features that you would need is more important. For basic CarPC functions like videos, music, gps, obdII, weather, phone, etc. Most atom, celeron, pentium, amd processors included with today's boards will do the trick. If you require certain features like serial port, sata HDs, dvi / vga, 6 channel onboard sound and so on, find boards that fit that and then compare processors to your liking. Remember that a lot of features you may want can be added in through USB if you can't find something that has everything you want.
    Also watch your power consumption. As a lot of us on these forums are computer savvy we tend to want "the best of whats out there", but many times for a CarPC it is just overkill. The more powerful of a PC you build the more expensive and difficult it will be to power properly in the car.
    Mar 2010
    Miami
    is there any reason for a ps2 port anymore? i have a full function usb keyboard with a touchpad that is usually detected right away by even my oldest computer. i feel like i wouldnt use it because I'd rather have a board with something more useful in place of a PS2 port.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by moetpoppin View Post
    I use my PS2 port to power a serial GPS receiver. I have used USB GPS receivers before with varying success when using hibernate. I switched to a serial receiver and it never ever fails.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Welcome, Im in Miami too! GOOOO MIAMIIIIIIIIIIIII! Except when its so f#*king hot outside.
    PS2 really isnt needed anymore. All MoBos pretty much have legacy USB support. I personally dumped 2 different MoBos for a Zotac. Those are awesome boards, feature rich and I hear the BIOS is farely fast. (I cant comment because mine isnt setup yet.) Anything with ION graphics is a plus. Plus 99.9% of Zotacs also come with built in Wi-Fi.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    I gave a lot of decissions into what mobo I should go for.
    I ended up with the Zotac ION and 4Gb RAM.
    Paired up with the Intel X25-m SSD I have a UNTWEAKED boot time of 24 seconds from a complete power off, until the PC is ready for use.
    (Windows Embedded 7 64-bit with "Application Friendly" install).
    With untweaked I mean that I have not done any changes to BIOS or optimized Windows.
    I have not tested resuming from hibernation.
    Jul 2007
    Miami
    Quote Originally Posted by Crinos View Post
    Can I pick your brain. Does the Windows embedded have EWF? If yes, does it still work like a normal Win 7 install. i want to use Win 7 but have the ability to use hybrid sleep.
    OK so thats 2 for Zotac, lol
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Elsewhere
    Windoze Embedded is a whole other animal.
    There are some write-ups ab out how to use it on mp3car, but there are far better resources if you want to get into an embedded OS.
    How about the Wiki?
  1. USB Controlled Relay Board or general output
    By 2k1Toaster in forum Hardware Development
    Last Post: 05-29-2007, 12:40 PM
  2. Lilliput Button Board IR Extension
    By FLESIK in forum LCD/Display
    Last Post: 02-13-2007, 03:58 AM
  3. PC Board Etch on Plexi
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 09-21-2005, 07:12 PM
  4. Replies: 4
    Last Post: 05-04-2005, 12:24 PM
