Results 11 to 20 of 30
Thread: ASUS AT3IONT-I Deluxe board
  1. #11
    Jun 2009
    i believe this is a 12volt board. at least that is what it looks like
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
  2. #12
    Mar 2010
    Quote Originally Posted by Sleepyz0mby View Post
    the power will more than likely be 19v (power brick info - first place i looked)
    I finally got a chance to look at the board and the adapter is almost identical to the one linked above.
    Model - ADP 90CD DB
    Input - 100-240V ~ 1.5A 50-60Hz
    Output - 19V ~ 4.74A
  3. #13
    Newbie michael063's Avatar
    Aug 2009
    this ASUS deluxe it's 12volt's board? or not? i not understand....
    Case - Neo Case (www.lex.com.tw)
    Proc - Intel Pentium M 1Ghz
    Chip - Intel 82852 GM
    HDD - 2.5" 120GB WD 5400RPM (SATA)+IDEtoSATA converter
    512 MB DDR2 PC5400
    XDX 7" Sensor TM - VGA Monitor
    MB - MI853AW (input voltage - wide range, 9V-32V)
  4. #14
    Jan 2008
    Dartmouth, MA
    SleepyZomby is probably right. I made an assumption which is probably incorrect.
    Nearly every asus DC power supply is 19 volts, this is probably the same. When you get the board, the power supply it comes with will almost definitely have the voltage printed on it. If not, you can always check with a multimeter.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  5. #15
    Mar 2010
    Any update on this, I'm looking to get the same board. I'm thinkin the P1900 or 2140 would do the deed, and I've been looking around for other options and can't quite find anything I'm really comfortable with.
  6. #16
    Mar 2010
    Here is a pic of the ASUS AT2IONT-I Deluxe power supply.
    The stripping the wire reveals that there is braided wire surrounding another insulated wire. Peeking under that insulation reveals the second braided wire. Sorry for the poor pic.
    I have not done further testing.
  7. #17
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Dual-channel DDR3 technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market.
    Wow, DDR3 on an Atom board? wtf...
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  8. #18
    Jan 2008
    on the power supply-- there is a spot that says "OUTPUT" it is a little blurry in your pic, so i can't tell wheather it reads 10,13,14,15,16,18,or 19 volts output, but that is the number you want to look at when looking for a power supply.
  9. #19
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    I have this board. It requires 19v input. I measured the ouput of the power brick, and it output at 19.4v. I use a Carnetix 2140 and set it to 20v output for this board....no issues.
    Let me know if you have any other questions.
  10. #20
    Jun 2007
    Sorry for reviving old thread, but, is there a way of using a smart Automotive powersupply for this?
    I wanted to use this board, but I did it to boot once it sees power?
  1. Replies: 34
    Last Post: 12-16-2009, 06:50 PM
  2. connecting a PSU to a board which doesn't a have 20 pin connector
    By al_kaholik in forum General Hardware Discussion
    Last Post: 12-02-2006, 02:21 PM
  3. FS /FT, touch module. plasma screen + more
    By BADDERICK in forum Classified Archive
    Last Post: 07-06-2005, 09:52 AM
  4. Motherboard: ASUS K8V-X (AMD64)
    By judoGTI in forum Classified Archive
    Last Post: 05-08-2005, 09:23 PM
  5. ASUS A8N-SLI Deluxe...
    By Seth in forum Off Topic
    Last Post: 12-14-2004, 03:33 PM
Tags for this Thread
