Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: ASUS AT3IONT-I Deluxe board
    Mar 2010
    I want to power the new ASUS AT3IONT-I Deluxe in my van. The board has DC power built in, and comes with a 90W Adapter & Power Cord. Great for HTPC users, not so much for me. How could I power this board without using an inverter?
    They also make a non-deluxe version which does not have on-board power or wifi...and is impossible to find for sale in the US.
    Any help is appreciated. Thanks.
    Jan 2008
    you might be able to power it using a laptop-type power supply, as long as the voltage output of the a/c adapter, and the dc-dc unit are the same--i can't seem to find the voltage output of the power supply, so can't be sure..
    Mar 2010
    Yes, that most likely will be the best way to go. I have found a couple of websites that may sell what I need when I determine the voltage. http://www.lindelectronics.com and http://powerstream.com seem like they may be helpful, but that solution is also expensive.
    I ordered that board today and hopefully will be able to make some progress when it arrives.
    Jun 2009
    P2140 will do it as long as you set it up right. I am using that now to power my carpc and works. that board is really nice. It is the upgrade to the one i got a few months ago.
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
    Jan 2008
    Dartmouth, MA
    You'll have to take a standard intelligent automotive PSU and cut off a hard drive connector then take the yellow wire (+12 volts) and the black wire closest to it and then connect them to the power connector from the included power supply.
    The startup/shutdown control will just be taken care of by the power button header on the motherboard. Most intelligent PSUs just have a connector that hooks up to it.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jan 2008
    Quote Originally Posted by PaulF View Post
    careful about the power requirements-- i know some of the zotac and intel boards with a single power input require a 19 volt dc power supply-- so a standard atx power supply might or might not work, depending on the board.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    this is what i use just cut the light socket adapter off and wire to 12v fused line
    http://www.canadacomputers.com/index...id=NBK.276.844
    SNO
    Jan 2008
    that would work, assuming that it outputs the correct voltage.
    but that would not auto power on/off the computer-- you need a inteligent power supply to do that
    Mar 2010
    So when I get the board in a few days, how do I determine the voltage? Is it possible the power supply adapter will have the voltage printed on it?
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    sorry to step on your toes PaulF...
    the power will more than likely be 19v (power brick info - first place i looked)
    ima go out on a limb here and guess that power brick is the same (19v?) as the itxion and mag from zotac, assume they are the same -HERE- is 1 power solution (read thoroughly cause its not perfect) that was reviewed.
    P2140 is a bit over kill IMHO but so is the board for a car pc...
  1. Replies: 34
    Last Post: 12-16-2009, 07:50 PM
  2. connecting a PSU to a board which doesn't a have 20 pin connector
    By al_kaholik in forum General Hardware Discussion
    Last Post: 12-02-2006, 03:21 PM
  3. FS /FT, touch module. plasma screen + more
    By BADDERICK in forum Classified Archive
    Last Post: 07-06-2005, 10:52 AM
  4. Motherboard: ASUS K8V-X (AMD64)
    By judoGTI in forum Classified Archive
    Last Post: 05-08-2005, 10:23 PM
  5. ASUS A8N-SLI Deluxe...
    By Seth in forum Off Topic
    Last Post: 12-14-2004, 04:33 PM
Tags for this Thread
